Coolbluelights Posted September 19, 2013 Share Posted September 19, 2013 I have a mk5 fiesta (2001) 1.25 ghia 5 door and the air bag light flashed once then went out, then flashed once again then went out again, then stayed on after 5 times of flashing I took it to a fords dealer and they hooked it up to a pc and it came back with a faulty clock spring. i ordered a new one;fitted it this evening, put it all back together again and this time a new air bag flash sequence appeared. this time it flashes 3 times then goes off, flashes 3 times then goes off and after 5 times of it doing this it stays on constantly i googled the flash sequence and this is what i found "Three flash cycle: Short to battery plus or ground in section of air bag squib circuit common to both driver and passenger air bag modules" I haven't got a passenger airbag, just seatbelt pre tensioners and drivers air bag. what does that quote mean? cheers bradley Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 19, 2013 Share Posted September 19, 2013 I'd say a connector is off somewhere. Check the pins on the clock spring plug. Quote Link to comment Share on other sites More sharing options...
Coolbluelights Posted September 19, 2013 Author Share Posted September 19, 2013 i have checked them 3 times, they are fine, anything else you reckon it could be Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted September 19, 2013 Share Posted September 19, 2013 Have you tried disconnecting the positive battery csble and touching it to the negative terminal to clear residual charge in the wiring? Quote Link to comment Share on other sites More sharing options...
