jeebowhite Posted December 25, 2013 Share Posted December 25, 2013 Hi Guys, I can't recall what you need to recode if you replace the PCM? can anyone remind me? Basically I found my PCM isn't supported on the ELM Config software at the moment :( I was hoping I could buy it cheap from a scrappie and maybe just see if I could swap it, but I doubt that will happen lol. Quote Link to comment Share on other sites More sharing options...
FOCA Posted December 26, 2013 Share Posted December 26, 2013 Why would you want to change your PCM? Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 26, 2013 Author Share Posted December 26, 2013 The one I have is old and not supported by the ELM software, lol. I doubt that I would do it, but I am just humouring the idea of the work involved in changing the PCM over to one that supports the software so I can configure it... Quote Link to comment Share on other sites More sharing options...
FOCA Posted December 29, 2013 Share Posted December 29, 2013 The one I have is old and not supported by the ELM software, lol. I doubt that I would do it, but I am just humouring the idea of the work involved in changing the PCM over to one that supports the software so I can configure it... It might be easier/ better to leave the PCM and change the ELM software If you change your PCM,(AKA ECU ) you would need to recode it to your injectors, your PCM is probably coded to your BCU (body control unit) which is coded to your key(s) and ;locks, recoding the BCU/ key(s) is normally a dealer job (and realatively expensive) On top of that, the PCM you aquire is probably identical to the one you have (so still not supported by the elm software/ and then stlll needing coded to the injectors etc) or, incompatible (won't work) with the other components on the car So in a nutshell - forget it, not worth the hassle - better to leave the PCM/ car electronics alone and try another plug in solution/ code reader etc Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted December 30, 2013 Author Share Posted December 30, 2013 I thought that would likely be the case, lol. I wish I had Ford IDS as a clone, I just cant spend £300 on it :p I will keep in contact with Civil-ZZ and see if he is willing to cater for my PCM, if not, I will have to wait and see how it pans out... Quote Link to comment Share on other sites More sharing options...
