Johnny Men Posted March 17, 2014 Share Posted March 17, 2014 Hi, My wife has a 2011 Fiesta 1.25 Zetec. On the same journey the brake pedals "feel" changes - sometimes it's normal and then on the next application, it sinks towards the floor and you get very little braking effect - a bit disconcerting! It was serviced in February, the brake fluid level is fine, brakes are fine. it has pads front, drums rear. Independant garage inspected it today, no leaks, brake fluid condition fine, brake efficiency is fine (brake tester/rolling road) - he suspects the brake master cylinder. Anyone experienced similar? Any thoughts/advice would be appreciated. Thanks in advance. John Quote Link to comment Share on other sites More sharing options...
wase16ll Posted March 18, 2014 Share Posted March 18, 2014 have you had any work done on the brakes before this problem started? if so, though ive not experienced it myself, have heard its possible air can trap in the abs unit, which can give a similar condition..if no work has been done to the brakes, then this is unlikely to have happened, so would then agree with the master cylinder being the likely culprit. though i would have all the brakes physicaly checked before condemning the master...for example, you may have a rear wheel cylinder sticking 1 Quote Link to comment Share on other sites More sharing options...
Mike77 Posted March 18, 2014 Share Posted March 18, 2014 Common fault on these (know from experience) is the electronic control unit, more commonly know as the abs unit. Quite costly at around £340 fitted. Mine had excessive travel on pedal, which I considered to be dangerous, luckily it was an advisory on previous MOT before I purchased the car, so the garage got ford to replace the part before I picked up the car. After looking into the problem (just out of curiosity) it seems quite wide spread. Quote Link to comment Share on other sites More sharing options...
Johnny Men Posted March 18, 2014 Author Share Posted March 18, 2014 Thanks, I saw the abs thing elsewhere too, but not had any work done on brakes. Already been inspected and no visible signs of leaks, they also put it on their MOT brake tester and all individual wheels braking fine. I will mention the abs thing to them as an idea. Quote Link to comment Share on other sites More sharing options...
Mike77 Posted March 18, 2014 Share Posted March 18, 2014 All my brakes were working fine, and no leaks, but the amount of travel on the pedal was enough for it to become an advisory on the MOT. Quote Link to comment Share on other sites More sharing options...
wase16ll Posted March 18, 2014 Share Posted March 18, 2014 Wouldn't take too much notice of the brake roller test unless the pedal dropped at time of test.. Would recommend a proper and full physical check of the brakes. The abs module can go faulty, but it sounds like air is getting into system, which is more likely a master cylinder fault than abs, unless work was carried out on brakes before the problem started...and as stated elsewhere, if air is in abs, can be bled out via duagnostics Quote Link to comment Share on other sites More sharing options...
Johnny Men Posted March 18, 2014 Author Share Posted March 18, 2014 Thanks everyone for the thoughts and ideas so far. A proper inspection was done on Monday, road roller brake test, water content in brake fluid checked, on ramp inspection etc To clarify, no work has been done on the brakes previously. Thanks again John Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
