sonic113
Best Oil For Smooyther Engine
6 posts in this topic
just wondering whats the best oil to get the smoothest running engine on the ford 1.6 zetec
castrol magnatec 5w30 or the ford formual f 5w30?
also is this castrol magnatec any good or is it just a sales ploy and is the ford formula f the best oil for the focus?
i like the idea of the partcles in it sticking to the engine parts for quiet running and protection on cold starts but does it actually work or as i day just another sales ploy??
The Ford Formula F oil is made by Castrol. Based on product specifications the Ford Formula F oil should be same as the Castrol Magnatec 5w30 A1/B5 oil.
Castrol is the only oil brand which is recommended/approved by Ford.
For standard protection Ford recommends the Formula F oil.
For advanced protection Ford recommends the Castrol Magnatec professional 5w30 A5 oil.
In my opinion Both oil types will be fine. Until now I used both the Formula F oil and the Castrol magnatec A1/B5 oil. Generally both types of oil can be bought online for approximately same prices. Last time I paid about €30,- for a 5 liter can of Ford Formula F oil. The Castrol Magnatec professional oil will probably be a little more expensive.
thanks
JW1982 for reply.
i think i will use the formual f as i dont think i would be gaining anything with the magnatec option.
along the same subject whats the best spark plugs you would recommend for the 1.6 mk2.5 zetec focus?
I use NGK TR5B-13 spark plugs for my 1.6 Duratec Focus MK2. My experience is that these spark plugs perform very well. I buy them from a shop in the UK for about £8,50 including P&P. Despite my low mileage I change the spark plugs every 2 years.
Another possibility will be the NGK PTR5A-13 Platinum spark plugs. These have a longer changing interval but are also more expensive.
Mobil is also a very good oil mate. I use the mobil 5w30 fully synthetic
Hiya
Change it twice a year, Fully Synthetic, The Best you can afford, After all less than £100 buys the oil £2000 or more gets you a new engine !!!
Jamie
