chrisehb Posted May 7, 2014 Share Posted May 7, 2014 Hi all,I have a Ford Fiesta Blue SE, 08 plate.My little one decided when she was sitting in the car to put a paper clip in the Cigarette lighter socket which is next to the gear stick, there were some sparks and slight pop, ever since it's stopped working.Is it just a case of removing it from the fitting and getting a replacement and connecting the power backup or is it a bit more complicated than that? Sorry if there is a guide, but I couldn't find one earlier.Chris Quote Link to comment Share on other sites More sharing options...
alexp999 Posted May 7, 2014 Share Posted May 7, 2014 I would have thought it is the fuse which has gone rather than the socket itself. Quote Link to comment Share on other sites More sharing options...
chrisehb Posted May 7, 2014 Author Share Posted May 7, 2014 I would have thought it is the fuse which has gone rather than the socket itself. Oh okay, is there located somewhere accessible where I could look myself? I know my old, old fiesta had a box to the right of the steering wheel where this could be found, but not sure on this model. Quote Link to comment Share on other sites More sharing options...
alexp999 Posted May 7, 2014 Share Posted May 7, 2014 It is usually behind the glovebox on most of the recent Fords, is yours the mk6.5? It might say in the manual which fuse it is (and the box location). Quote Link to comment Share on other sites More sharing options...
chrisehb Posted May 7, 2014 Author Share Posted May 7, 2014 Yeah I believe so.The fuses are defiantly behind the glove box, and I believe I need a 15a. (http://www.halfords.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&productId=753513&catalogId=10151) one of them?Chris Quote Link to comment Share on other sites More sharing options...
alexp999 Posted May 7, 2014 Share Posted May 7, 2014 That looks like a relay rather than a fuse. From what I have read you need a 15A fuse, but I don't know specifically what type for your car. Hopefully someone on here with the same car can give you the info if you can't find it in your manual or online Quote Link to comment Share on other sites More sharing options...
chrisehb Posted May 7, 2014 Author Share Posted May 7, 2014 Yeah I'm having a quick look on-line, it's defiantly a 15A fuse as you said. Apparently there is a fuse diagram behind the Glove box so I'm going to take a look later and post where I find. Do you know if its a Mini blade fuse, or a fuse as you would find in an electrical socket? Quote Link to comment Share on other sites More sharing options...
Sheriff Posted May 7, 2014 Share Posted May 7, 2014 Should be a mini blade. Also, check your rear lights are working... Quote Link to comment Share on other sites More sharing options...
chrisehb Posted May 7, 2014 Author Share Posted May 7, 2014 Should be a mini blade. Also, check your rear lights are working... Yeah they are, everything else it working fine. Does anyone have a diagram of the Fiesta so I can try to replace tomorrow? Quote Link to comment Share on other sites More sharing options...
