djspoole Posted September 23, 2014 Share Posted September 23, 2014 Hi i own a 1999 ford fiesta ghia 16v. The problem i have is my heater is always blowing hot air,also it only works on full power (4).. I would like someones feedback on this as it was a nightmare in the summer thankyou... Quote Link to comment Share on other sites More sharing options...
kevzs960 Posted September 23, 2014 Share Posted September 23, 2014 Heater control valve underneath the scuttle pannel Sent from my GT-I9195 using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
djspoole Posted September 23, 2014 Author Share Posted September 23, 2014 Thankyou Kevs960.... Quote Link to comment Share on other sites More sharing options...
kevzs960 Posted September 23, 2014 Share Posted September 23, 2014 Providing the wiring is ok. Thats normally the common problem for your symptoms Sent from my GT-I9195 using Ford OC mobile app 1 Quote Link to comment Share on other sites More sharing options...
djspoole Posted September 23, 2014 Author Share Posted September 23, 2014 Providing the wiring is ok. Thats normally the common problem for your symptoms Sent from my GT-I9195 using Ford OC mobile app I have already ordered one from eBay for £10.....no idea how to search for the hoses thou....I wanted to buy those as well just in case.... Quote Link to comment Share on other sites More sharing options...
djspoole Posted September 25, 2014 Author Share Posted September 25, 2014 Providing the wiring is ok. Thats normally the common problem for your symptoms Sent from my GT-I9195 using Ford OC mobile app I have just fitted the New heater control valve but still have exactly the same problem. Just to let you know there was not a control valve fitted,there was just 2 short bits of pipe connecting the pipes together... The thing that is confusing me is that the heater used to work ok without it.... Any ideas...Maybe a fuse or something.... Quote Link to comment Share on other sites More sharing options...
shaunytee1600 Posted September 25, 2014 Share Posted September 25, 2014 Upload a pic let's see.:) Power is nothing without control . Quote Link to comment Share on other sites More sharing options...
Dan62 Posted September 26, 2014 Share Posted September 26, 2014 Hope the attached helps, unlikely to be a fuse as they are used for other circuits so you would have noticed other things not working too. But you should check them anyway. It just leaves wiring or heater control module as suspects. As for the blower only working on high speed you probably need a new resistor pack (R21) behind dash panel, centre, near air conditioning/heating control unit Quote Link to comment Share on other sites More sharing options...
djspoole Posted September 28, 2014 Author Share Posted September 28, 2014 Hope the attached helps, unlikely to be a fuse as they are used for other circuits so you would have noticed other things not working too. But you should check them anyway. It just leaves wiring or heater control module as suspects. As for the blower only working on high speed you probably need a new resistor pack (R21) behind dash panel, centre, near air conditioning/heating control unit Thankyou for you help i am just ordering the part now,i will let you know if it works...thanks. Quote Link to comment Share on other sites More sharing options...
djspoole Posted September 29, 2014 Author Share Posted September 29, 2014 Hope the attached helps, unlikely to be a fuse as they are used for other circuits so you would have noticed other things not working too. But you should check them anyway. It just leaves wiring or heater control module as suspects. As for the blower only working on high speed you probably need a new resistor pack (R21) behind dash panel, centre, near air conditioning/heating control unit Thank you for the information provided. I have purchased a new resistor pack and plug with 4 short wires.. On inspection of the old one it has a burn on the inside of one of the 4 pins, and melted the plastic a little. I am a bit worried about putting the new switch in and connecting it up. Is there any precautions i need to take before i connect it all back up. Thank you in advance. Quote Link to comment Share on other sites More sharing options...
Dan62 Posted September 30, 2014 Share Posted September 30, 2014 I would cut the old connector off and splice the new connector onto the loom. Ideally solder and insulate the wires but you could use a connector block (chocolate block) or in-line crimps if the cable length on the new connector permits. Quote Link to comment Share on other sites More sharing options...
