WELSHSTEVE Posted October 2, 2014 Share Posted October 2, 2014 I have a 58 plate 2Ltr mondeo estate, 157,000 miles i have also developed a loud rumbleing noise on the belt side of the engine.. the rumble noise is only there at tickover, and the beit vibrates quite a bit. when revs are up to 100rppm every thing goes quiet and runs smoothley. could this be as "advised by a friend" the clutch in the Alternator pulley. I didn't know an Alternator even had a clutch. or somthing else? Please help Quote Link to comment Share on other sites More sharing options...
Ben87 Posted October 4, 2014 Share Posted October 4, 2014 Hi The older Mondeos (mk3) were really bad for the fan belt tensioner and crank pulley dampers for going. I'm not a hundred percent if the newer Mondeos have the same kind of setup but could be worth having someone look at them too to make sure there ok. Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
