Mental_Atom Posted November 8, 2014 Share Posted November 8, 2014 It's a nightmare! Or is it just me? One of my little plastic screw-clip things has stripped so the headlight doesn't come out, so I had to change one of the bulbs in situe which was a huge pain! Also, the clip under the headlight is a massive pain, so hard to get it out and get it back in! Is it just me who thinks it's a rage-inducing process? Share your rants here :D Quote Link to comment Share on other sites More sharing options...
MarksST Posted November 8, 2014 Share Posted November 8, 2014 You were probably being too gentle with it, the clip on the slam panel just needs prising out, the clip underneath just need a quick pull upwards. Quote Link to comment Share on other sites More sharing options...
Mental_Atom Posted November 8, 2014 Author Share Posted November 8, 2014 You were probably being too gentle with it, the clip on the slam panel just needs prising out, the clip underneath just need a quick pull upwards. I tried prising it, but I just got loads of scratches on the panel, cut myself, and it didn't come out. I seem to be terrible at car maintainence :L Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted November 10, 2014 Share Posted November 10, 2014 I had the exact same problem with the little screw clips, definitely rage-inducing as you say. I stripped one of them but managed to get it out somehow. I also couldn't just prise it out until I could get the screw out of the clip, maybe that could be done with a screwdriver (by prising the screw out of the clip first) because then the clip comes straight out. Quote Link to comment Share on other sites More sharing options...
BigDaveZS125 Posted November 10, 2014 Share Posted November 10, 2014 It's a nightmare! Or is it just me? One of my little plastic screw-clip things has stripped so the headlight doesn't come out, so I had to change one of the bulbs in situe which was a huge pain! Also, the clip under the headlight is a massive pain, so hard to get it out and get it back in! Is it just me who thinks it's a rage-inducing process? Share your rants here :D I didn't fully take my units out to change mine, I just undid the top and bottom screws and lifted them up just enough to get to the bulbs :) was a bit fiddly but managed to keep all my fingers ;) haha Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
MattDRX Posted November 11, 2014 Share Posted November 11, 2014 Think my NS is held in by Gravity alone, that giant clip is a mare snapped it right off and the clips wouldn't come out so I snapped em off like a BOSS! 2 Quote Link to comment Share on other sites More sharing options...
Mental_Atom Posted November 11, 2014 Author Share Posted November 11, 2014 Well, I'm glad I'm not the only one who's had crazy issues with them. Has to be said there's no chance of them being insecure though lol Quote Link to comment Share on other sites More sharing options...
MattDRX Posted November 11, 2014 Share Posted November 11, 2014 I tried to get Ford to replace the clip FOC, nothing in the manual says there is a clip there, it just says unscrew and lift off. which in reality means yank it off as hard as you need to. Quote Link to comment Share on other sites More sharing options...
Mental_Atom Posted November 11, 2014 Author Share Posted November 11, 2014 I tried to get Ford to replace the clip FOC, nothing in the manual says there is a clip there, it just says unscrew and lift off. which in reality means yank it off as hard as you need to. Yeah it's ridiculous. You also have to remove the small plastic clip which the manual also says nothing about. Quote Link to comment Share on other sites More sharing options...
Jeff4155 Posted November 11, 2014 Share Posted November 11, 2014 There is a very good explenation on how to take your lights out on this site, I made use of it, in the end its still the hardest car to change a light bulb on that I have worked on, good luck Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted November 11, 2014 Share Posted November 11, 2014 There is a very good explenation on how to take your lights out on this site, I made use of it, in the end its still the hardest car to change a light bulb on that I have worked on, good luck Do you have a link? I might have seem that before but can't remember where it is. Quote Link to comment Share on other sites More sharing options...
Jeff4155 Posted November 12, 2014 Share Posted November 12, 2014 Do you have a link? I might have seem that before but can't remember where it is. http://www.fordownersclub.com/forums/tutorials/article/185-guide-mk7-fiesta-bulb-change/ Found it! Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted November 12, 2014 Share Posted November 12, 2014 http://www.fordownersclub.com/forums/tutorials/article/185-guide-mk7-fiesta-bulb-change/ Found it! Cheers, that should be useful next time I need to remove them :) Quote Link to comment Share on other sites More sharing options...
Philf1 Posted November 12, 2014 Share Posted November 12, 2014 You should try a clio sport if you think the fiesta is hard Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Phil 87 Posted November 12, 2014 Share Posted November 12, 2014 You should try a clio sport if you think the fiesta is hard Lol you're probably right, all my complaining and the Fiesta is probably one of the easiest cars to work on. Quote Link to comment Share on other sites More sharing options...
Philf1 Posted November 12, 2014 Share Posted November 12, 2014 Ask Tom when you see him he'll tell you about it Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
dmizz93 Posted November 12, 2014 Share Posted November 12, 2014 You can change the main beams in situ for about two mins aside... Okay the first one took me 10 but the second one literally a minute.. Dipped you have to take the unit off unless you fancy modifying your washer fluid reservoir :P Sent from my iPhone using Ford OC Quote Link to comment Share on other sites More sharing options...
NathJ Posted December 23, 2014 Share Posted December 23, 2014 I agree! It is an absolute nightmare. I mean I am a bit handy with tools and fixing things etc but changing the bulbs is an absolute farce with this car ha! Granted that if you have hands like a spatula then you may be able to get away with not having to take the whole unit off to replace/remove them. Also I made a big boo boo, well when I say that I mean that I'm sure an elf or something had stolen from me. Basically I had the two torx headlight screws in my pocket and leaned over in my car to press the clutch and start the car with my hands and I heard the two screws fall out of my pocket. Conveniently one of them fell in the cupholder but the other one is nowhere to be seen in my car, bearing in mind the car is brand new and there is absolutely no clutter or anything in it, I spent a good 40 mins checking every crevice but I cannot for the life of me find it in my car! So I have made the conclusion that it has been stolen or could have been magic right? So my question is where can I get a replacement headlight screw online? I think that they are torx 27 if I am right in saying. Cheers in advance guys. Quote Link to comment Share on other sites More sharing options...
Mental_Atom Posted December 23, 2014 Author Share Posted December 23, 2014 I agree! It is an absolute nightmare. I mean I am a bit handy with tools and fixing things etc but changing the bulbs is an absolute farce with this car ha! Granted that if you have hands like a spatula then you may be able to get away with not having to take the whole unit off to replace/remove them. Also I made a big boo boo, well when I say that I mean that I'm sure an elf or something had stolen from me. Basically I had the two torx headlight screws in my pocket and leaned over in my car to press the clutch and start the car with my hands and I heard the two screws fall out of my pocket. Conveniently one of them fell in the cupholder but the other one is nowhere to be seen in my car, bearing in mind the car is brand new and there is absolutely no clutter or anything in it, I spent a good 40 mins checking every crevice but I cannot for the life of me find it in my car! So I have made the conclusion that it has been stolen or could have been magic right? So my question is where can I get a replacement headlight screw online? I think that they are torx 27 if I am right in saying. Cheers in advance guys. Haha, definitely magic. Somebody must have asked for one for Christmas so an elf came and stole it! :P If I remember correctly you can use torx or flat-blade screwdrivers to open them (that's why they're a weird shape). It threw me too! Quote Link to comment Share on other sites More sharing options...
NathJ Posted December 23, 2014 Share Posted December 23, 2014 Haha, definitely magic. Somebody must have asked for one for Christmas so an elf came and stole it! :P If I remember correctly you can use torx or flat-blade screwdrivers to open them (that's why they're a weird shape). It threw me too! Haha, believe me that it drove me up the wall so much so that I was questioning myself and even starting looking in the glovebox! Yes, you can use a long/large flat head on it as well but it would ideally be for a torx head which I didn't have so I also used a flat head reluctantly as I didn't want to crush the screw head pattern, but as long as you have one that fits into it snug then it should be fine. Seems like it is going to be a long day looking for a replacement as I can't seem to find one just yet! Quote Link to comment Share on other sites More sharing options...
Paramanic Posted December 23, 2014 Share Posted December 23, 2014 I thought it was quite easy lol took ten mins for two bulbs lol (fully taking units out ) but changed ma da's Corsa headlights now that's annoying! Quote Link to comment Share on other sites More sharing options...
Philf1 Posted December 23, 2014 Share Posted December 23, 2014 I thought it was quite easy lol took ten mins for two bulbs lol (fully taking units out ) but changed ma da's Corsa headlights now that's annoying! Serves you right for having a c***a lol Sent from my iPhone using Ford OC mobile app Quote Link to comment Share on other sites More sharing options...
Mental_Atom Posted December 23, 2014 Author Share Posted December 23, 2014 Serves you right for having a c***a lol Sent from my iPhone using Ford OC mobile app My sister the other day was like "but your corsa or whatever it is isn't as good as (other new car)". I was like "Corsa? CORSA?" :P Quote Link to comment Share on other sites More sharing options...
b1g_dav3 Posted December 23, 2014 Share Posted December 23, 2014 The sidelight bulbs are a royal pain in the !Removed!, what the heck are those stupid stalks all about? Pretty sure one of mine is now broken >_> Quote Link to comment Share on other sites More sharing options...
Paramanic Posted December 24, 2014 Share Posted December 24, 2014 Serves you right for having a c***a lol Sent from my iPhone using Ford OC mobile app Not ma car! Lol he only got it because he got it for buttons brand new and uses it for work so doesn't really care about it said he woulda got a Ford but didn't want to ruin it Quote Link to comment Share on other sites More sharing options...
