GJC Posted January 29, 2015 Share Posted January 29, 2015 Hi Anyone know how the power is routed in/out of the Quick Clear screens? Mines not working on the passenger side, not the fuse, however since I out a dashcam in its now worked. Could be it went last year and I've had no cause to use it., but is there a power or earth feed at the top that I may have damaged / dislodged when I pushed the cable behind the head trim? And if I have how do I get the ceiling trim off to check???? Or if someone can tell me that I can check myself... Ta... Quote Link to comment Share on other sites More sharing options...
troy45 Posted January 29, 2015 Share Posted January 29, 2015 On most cars I'm aware of the heated screen connections come from the engine bay wiring loom, going to the bottom of the screen and not routed under the headliner. This would be backed up if on your car any fuses for the screen are located in the engine bay fusebox rather than the junction box inside the car. Quote Link to comment Share on other sites More sharing options...
GJC Posted January 30, 2015 Author Share Posted January 30, 2015 Does it earth out by the same rout, ie the engine bay, or is the earth at the top (ie the power "flows up" the screen? Quote Link to comment Share on other sites More sharing options...
GJC Posted February 3, 2015 Author Share Posted February 3, 2015 Can anyone post a FINIS screenshot as that may have rough connector locations on it? Quote Link to comment Share on other sites More sharing options...
