Slyatslys Posted March 29, 2015 Share Posted March 29, 2015 Mk2 (07 plate) 100K 1.8 TDCi My wife was driving my car when suddenly the temp gauge hit the red and the displayed referred to overheating plus usual selection of dash lights. She stopped and waited until we arrived. We added more water and noted it appeared to be leaking out even as we were filling it up. The leak appears to be on the drivers side and is being splashed around by the pulley system so it is very hard to see where the leak is from the top as you get a face full of spray. This happens when the car is cold or hot and looks like it is well beyond my fixing capability on the drive. I don't think it is the thermostat housing as I read that this is normally more obvious an issue when the engine is hot but I could have misunderstood. Seems more like the coolant pump or something in that area? Is this a common issue? This did not seem to be in the common issues thread but then I might have missed it as I was running through it. I am after some ideas as to what it is likely to be so that when the garage come back with their assessment I am at least semi informed. Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 29, 2015 Share Posted March 29, 2015 Sounds like its the water pump or pump hose if you get under the car it should be obvious 1 Quote Link to comment Share on other sites More sharing options...
sonic113 Posted March 29, 2015 Share Posted March 29, 2015 yes have a look and try to locate where its coming from firstly. after this you will get a better idea of what needs fixed. hopefully its an easy fix for you. Quote Link to comment Share on other sites More sharing options...
IINexusII Posted March 29, 2015 Share Posted March 29, 2015 There is a T-pipe where the belts are, that was one that leaked alot for me, might be a good idea like the others said to give the area a dry and check where the source is Quote Link to comment Share on other sites More sharing options...
artscot79 Posted March 29, 2015 Share Posted March 29, 2015 On some if not all theres another thermostat after the t pipe if that stuck shut the hose would likely burst or split the t pipes in sure are plastic so cracking is a possibility also Quote Link to comment Share on other sites More sharing options...
Shennas Posted March 29, 2015 Share Posted March 29, 2015 Mk2 (07 plate) 100K 1.8 TDCi My wife was driving my car when suddenly the temp gauge hit the red and the displayed referred to overheating plus usual selection of dash lights. She stopped and waited until we arrived. We added more water and noted it appeared to be leaking out even as we were filling it up. The leak appears to be on the drivers side and is being splashed around by the pulley system so it is very hard to see where the leak is from the top as you get a face full of spray. This happens when the car is cold or hot and looks like it is well beyond my fixing capability on the drive. I don't think it is the thermostat housing as I read that this is normally more obvious an issue when the engine is hot but I could have misunderstood. Seems more like the coolant pump or something in that area? Is this a common issue? This did not seem to be in the common issues thread but then I might have missed it as I was running through it. I am after some ideas as to what it is likely to be so that when the garage come back with their assessment I am at least semi informed. Seams unlikely if it a large amount of water to be the pump. Most like a pipe has split. Don't drive the car as you could warp the head. Quote Link to comment Share on other sites More sharing options...
