MTL Posted May 26, 2015 Share Posted May 26, 2015 Had an incident in the car where a pole I was transporting (not the nationality) slid through between the driver and passenger seats and bashed the radio. It clonked the display and the 'ink' spread across an inch or so of it inside the glass/plastic. Subsequently, I can't read what station it is or search or do whatever to the menu. It's a bog standard 6000 radio cd player. I enquired with a local car radio guy and he says it'd cost £100 to sort it. Is there a cheaper way? I'm not that technically minded to be installing a new one or a replacement and actually thinking of selling the car (the button on the handbrake has slightly come apart too) but is there a handy or more cost effective way of sorting it? 1 Quote Link to comment Share on other sites More sharing options...
WES180 Posted May 26, 2015 Share Posted May 26, 2015 What model/year Focus do you have? Have you tried eBay for a complete used replacement radio instead? Quote Link to comment Share on other sites More sharing options...
MTL Posted May 26, 2015 Author Share Posted May 26, 2015 It's a Ford Focus Zetec estate 54 plate. No not tried eBay as I'm thinking this could be a job for a more technically minded person perhaps? Quote Link to comment Share on other sites More sharing options...
MTL Posted May 26, 2015 Author Share Posted May 26, 2015 I should also say thank you there WES180! 1 Quote Link to comment Share on other sites More sharing options...
WES180 Posted May 26, 2015 Share Posted May 26, 2015 You will be fine to sort this yourself. There are some 6000 radio's on eBay for around £40 delivered. You would need a set of removal keys too for around £3 delivered. That is going to be your cheapest option unless you have a local breakers yard that could save you on postage charges for the radio. 1 Quote Link to comment Share on other sites More sharing options...
MTL Posted May 26, 2015 Author Share Posted May 26, 2015 Ever changed one yourself? Quote Link to comment Share on other sites More sharing options...
WES180 Posted May 26, 2015 Share Posted May 26, 2015 Plenty of how to remove videos on eBay mate. You can do it!!! Some info on here too. http://www.fordownersclub.com/forums/topic/17797-help-6000cd-removal-!Removed!-removal-keys/ 1 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted May 26, 2015 Share Posted May 26, 2015 Five minutes to change one, just make sure you buy one with a code and not out of a Mondeo and you'll be fine. Quote Link to comment Share on other sites More sharing options...
Goodkat Posted May 26, 2015 Share Posted May 26, 2015 Wes is right, I would even trust my 8 year old daughter with hyperactivity issues to replace one of these. It really is childs-play, use removal keys to pull out old unit, disconnect the plugs, launch in nearest bin receptacle. Connect plugs into new unit, slide back into place, enter keycode and Bob is your mother's brother. Also, if you are selling it, it will add more value having a stereo which hasn't been unintentionally modified by a pole. I reckon a potential purchaser will try to use it as a negotiating point to knock money off. 2 Quote Link to comment Share on other sites More sharing options...
MTL Posted May 30, 2015 Author Share Posted May 30, 2015 How do I find out if the radio is the right model? I've seen lots of 6000s on eBay - some say Mondeo others Fiesta etc. Will it be as long as it looks the same as mine it will be the right one I need? Quote Link to comment Share on other sites More sharing options...
WES180 Posted May 31, 2015 Share Posted May 31, 2015 Buy the one that says its for a Focus as they can look the same but the sides can be contoured differently and you will not tell from the eBay pics, only when you slide it in the car and see it doesnt line up with the surrounding dashboard fascia. Quote Link to comment Share on other sites More sharing options...
