simon2710 Posted June 5, 2015 Share Posted June 5, 2015 Hi, I spent the whole day changing discs and pads on the rears of my Focus MK1.5 1.6 Zetec. The backing plates that go behind the disc are pretty much shot, they have rotted and are falling to pieces and were rubbing against the old discs. Would I actually need these for any purpose or would it be safe enough to remove them? Also how would I go about removing them apart from grinding them, is it a "hub-nut" job? Final question is where could I buy these at a good price if I need them, I know a good start might be Ford dealership parts as it is such a specific part? Many thanks Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 5, 2015 Share Posted June 5, 2015 Hi,the rivets can be drilled out that fix the splash guard to the tie-bar.Replacements don't need to be riveted back and held in place when the stub axle,hub assembly is bolted in place.Hope this helps. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
simon2710 Posted June 5, 2015 Author Share Posted June 5, 2015 Hi Williamweb, Many thanks, looks like I'll need to take discs off again. Can't seem to find any on eBay apart from RS and they looked plastic so should last a good while longer. Quote Link to comment Share on other sites More sharing options...
williamweb Posted June 6, 2015 Share Posted June 6, 2015 The RS tie-bar is the same as the standard car,I don't know if the splash guard is bigger though but plastic seems a good idea and the way to go. Sent from my iPad using Ford OC Quote Link to comment Share on other sites More sharing options...
