footfistart Posted June 26, 2015 Share Posted June 26, 2015 I have a new set if tail lights to install to my mk6 but have a couple of questions. Been looking at the guide and doesn't make a lot of sence. Looks a bit of a mess and I hate mess like that. So there must be an easier way ie depin and solder new wire to existing one. I'm not one for cutting wire ect as my electric skills are crap which is why a mate of mine is doing it. So all I need to do is run two more wires from either side (left to right or right to left) from fog to fog nd reverse to reverse. Cant be much else to that right? I'll be running cables with the existing loom so I don't run risk of chaffing wires and causing problems. Many thanks Ryan Quote Link to comment Share on other sites More sharing options...
footfistart Posted June 26, 2015 Author Share Posted June 26, 2015 Could you not get the facelift plug from its own wireloom so that you would have the same plug both sides and wire it up that way instead? I think that would be easier than chopping everything up. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted June 26, 2015 Share Posted June 26, 2015 I have a guide on my profile, I'll link in a minute. All of the wiring is different. Easiest way to do it is solder the facelift connector onto the prefacelift wiring. After completely rewiring you then have to run an insulated 2 core cable through the bottom of the boot Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted June 26, 2015 Share Posted June 26, 2015 It's amongst this somewhere :) http://www.fordownersclub.com/forums/index.php?/topic/63136-Fiesta-Mk6-Headlight-Hid-Retrofit Fiesta Mk6 Headlight Hid Retrofit If you can't access the file containing the wiring, I can email you it Quote Link to comment Share on other sites More sharing options...
footfistart Posted June 26, 2015 Author Share Posted June 26, 2015 I've found the excel file but do you have any pictures? Can't see those unfortunately. Thanks for your help. Ryan Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted June 26, 2015 Share Posted June 26, 2015 I don't have any pictures of the finished wiring anymore I'm afraid. Quote Link to comment Share on other sites More sharing options...
