yunii Posted July 2, 2015 Share Posted July 2, 2015 Hi can anyone tell me when adding sideskirts, are these bolted on bonded? Also does the plastic cover over the sills need to be removed? Cheers Yunii 1 Quote Link to comment Share on other sites More sharing options...
Brigante Posted July 3, 2015 Share Posted July 3, 2015 remove the plastic and just bond them on with tigerseal/very strong double sided tape 1 Quote Link to comment Share on other sites More sharing options...
Wheels93 Posted July 4, 2015 Share Posted July 4, 2015 When ford add them there is a retaining clip on the front part which faces towards you. If you get ford to fit them, this means they will drill a hole in the body to connect them. This applies to the other part too where there is three if I can remember correctly! (Not good if you ever want to remove them) When I did mine the other month I bonded them using bond&seal. Horrible stuff but sticks like a beast! Unfortunately due to poor storage I had some sag in the in the middle of the side skirts so drilled a tad to stick a retaining clip in. Look great though. And yes the plastic sills do need removing! 1 Quote Link to comment Share on other sites More sharing options...
Wheels93 Posted July 4, 2015 Share Posted July 4, 2015 Hope this helps :) 2 Quote Link to comment Share on other sites More sharing options...
yunii Posted July 4, 2015 Author Share Posted July 4, 2015 Hope this helps :)Very valued info Thwnks. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 5, 2015 Share Posted July 5, 2015 Hi can anyone tell me when adding sideskirts, are these bolted on bonded? Also does the plastic cover over the sills need to be removed? Cheers Yunii Undo the few tork screws and pull down the plastic sill panel it also has some little white clips attached to the plastic these come out as part of the plastic sill. Surprising amount of dirt gathers inside these sills, this is from one side: Now removed, I recommend cleaning the area with a bucket of solution to remove all dirt rather than a hose because you don't want to force water through the holes in to the sill cavity, Keep the Torx screws for fitting the skirts and discard the plastic sills. Ready for skirts I recommend fitting a set of custom mud flaps to protect the skirts from stone chips, I can guide you on creating these if required, 2 Quote Link to comment Share on other sites More sharing options...
Wheels93 Posted July 5, 2015 Share Posted July 5, 2015 Don't discard of plastic sills if you are gonna go back... I sold mine for £25 ;) 1 Quote Link to comment Share on other sites More sharing options...
yunii Posted July 5, 2015 Author Share Posted July 5, 2015 Undo the few tork screws and pull down the plastic sill panel it also has some little white clips attached to the plastic these come out as part of the plastic sill. Surprising amount of dirt gathers inside these sills, this is from one side: Now removed, I recommend cleaning the area with a bucket of solution to remove all dirt rather than a hose because you don't want to force water through the holes in to the sill cavity, Keep the Torx screws for fitting the skirts and discard the plastic sills. Ready for skirts I recommend fitting a set of custom mud flaps to protect the skirts from stone chips, I can guide you on creating these if required, Great guide Lenny also thanks to Wheels93. I haven't bought them yet but will do pretty soon.Yunii 1 Quote Link to comment Share on other sites More sharing options...
WES180 Posted July 6, 2015 Share Posted July 6, 2015 Hope this helps :) Not really! 1 Quote Link to comment Share on other sites More sharing options...
Wheels93 Posted July 6, 2015 Share Posted July 6, 2015 Not really! Charming ;) 2 Quote Link to comment Share on other sites More sharing options...
WES180 Posted July 6, 2015 Share Posted July 6, 2015 Lenny, your guides are brilliant but are you not fed up now of a 20min job taking 2 days due to all the photos?;) 1 Quote Link to comment Share on other sites More sharing options...
WES180 Posted July 6, 2015 Share Posted July 6, 2015 Charming ;)Ha ha, out of curiosity what was supposed to be attached or was it with reference to your earlier post? 1 Quote Link to comment Share on other sites More sharing options...
Wheels93 Posted July 6, 2015 Share Posted July 6, 2015 So there are screws along the bottom of both the front and main parts. These screw holes will be available when you take the plastic sills off and present the side skirts to the car. These need to be rescrewed back in. Along the side of the car there is one retaining clip on the front piece and three clips on the main piece. You can either drill the body and bang the clips in or you can do what I did and bond them on. Inside the skirt there is a line you can stick the bond on ;) 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted July 6, 2015 Share Posted July 6, 2015 Lenny, your guides are brilliant but are you not fed up now of a 20min job taking 2 days due to all the photos?;)Not at all when the process involves escaping the wife, viewed in that perspective it actually feels pretty awesome man Plus I've built up such an archive of pictures now it helps when posting on the forum. 2 Quote Link to comment Share on other sites More sharing options...
SeanW Posted July 7, 2015 Share Posted July 7, 2015 It's either play with the car or end up expecting again :P Without the Focus, Lenny would be well on his way to being able to field a full football team by now :D Talking of your The Wife - what you done with her? Don't see her posting much? Quote Link to comment Share on other sites More sharing options...
