Benlavelle Posted January 4, 2016 Share Posted January 4, 2016 Morning all, I recently installed some DRL's to my 2012 Ford focus a couple of months ago however, this morning i noticed one of the DRL's is extremely faint / dim. When i take a look under the bonnet everything looks normal, one of the DRL's is working perfectly fine, the other one is really faint / dim, has anyone come across any similar issue or could recommend any advice? Ben. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 4, 2016 Share Posted January 4, 2016 Are they OEM DRLs on cheap chinese things? Do you have a picture? www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
Benlavelle Posted January 4, 2016 Author Share Posted January 4, 2016 Hey Ginger Flame, they are the cheap one's from China but I've read loads of reviews none of which claim short life span. I've just taken some photos but there not great.This is the dim DRL (drivers side) This is the normal one (passenger side) I've only had them for about 1-2 months so i don't know what's gone wrong. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 4, 2016 Share Posted January 4, 2016 How are they wired? www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
Benlavelle Posted January 4, 2016 Author Share Posted January 4, 2016 red wire - battery + Black wire - battery - blue wire - ignition (rear wiper fuse) wire wire - headlight for dimming Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 4, 2016 Share Posted January 4, 2016 red wire - battery + Black wire - battery - blue wire - ignition (rear wiper fuse) wire wire - headlight for dimming On behalf of all road users, thank you for using the dimming wire ;) Have you checked all of your connections? www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
Benlavelle Posted January 4, 2016 Author Share Posted January 4, 2016 I only noticed it this morning and I've just a quick look under the bonnet but nothing jumps out. I connected it all up with a soldering Iron and heat shrink so i though it would be fine. That being said I've messed with the wires a little but no luck. As you see form the photos there is some current getting through, they are just really dim. I'm assuming something has gone, but I don't know if it's the bulb or the relay. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 4, 2016 Share Posted January 4, 2016 I only noticed it this morning and I've just a quick look under the bonnet but nothing jumps out. I connected it all up with a soldering Iron and heat shrink so i though it would be fine. That being said I've messed with the wires a little but no luck. As you see form the photos there is some current getting through, they are just really dim. I'm assuming something has gone, but I don't know if it's the bulb or the relay. Are they multiple LEDs? Or one bulb inside the unit? Can't load all the pictures as I've bad signal at the minute When the other one dims, does it match the dodgy ones brightness? www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
Benlavelle Posted January 4, 2016 Author Share Posted January 4, 2016 It's a row of around 6 LED's (vertically) No you have to get really close to see that they are on very slightly. Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 4, 2016 Share Posted January 4, 2016 It's a row of around 6 LED's (vertically) No you have to get really close to see that they are on very slightly. I wonder if the LEDs are in series.. of so, if one goes faulty they all will www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
Benlavelle Posted January 4, 2016 Author Share Posted January 4, 2016 would they still be on very slightly? Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted January 4, 2016 Share Posted January 4, 2016 Depends what's wrong with the LED. It's possible there's a loose connection or a dodgy relay. Could be anything yet Do you have any chance of opening the unit? Do they not have any garentee? www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
Benlavelle Posted January 4, 2016 Author Share Posted January 4, 2016 Not with the LED lights, I did with the relay but that's only cheap anyways. Duno what to do. Quote Link to comment Share on other sites More sharing options...
Benlavelle Posted January 4, 2016 Author Share Posted January 4, 2016 http://www.ebay.co.uk/itm/LED-Daytime-Running-Lights-Lamp-DRL-REPLACEMENT-fit-for-FORD-FOCUS-11-12-13-/191094888820?fits=Car+Make%3AFord%7CModel%3AFocus%7CPlat_Gen%3AMK+III&hash=item2c7e249974:g:ZawAAOSwQoFWPXCx that's similar to what I have installed. Quote Link to comment Share on other sites More sharing options...
