Colin1969 Posted February 26, 2016 Share Posted February 26, 2016 Is the tyre monitor system for detecting sudden pressure loss or does it let you know when more air is required over natural loss ? Meaning one does not have to check with a gauge every two or 3 weeks ? Thanks Quote Link to comment Share on other sites More sharing options...
Shelby - Fiesta Zetec S Posted February 26, 2016 Share Posted February 26, 2016 It usually only tells you when the tyre is loosing pressure quick unless you have tyre pressure sensors which display the pressure of each tyre Quote Link to comment Share on other sites More sharing options...
karl46 Posted February 26, 2016 Share Posted February 26, 2016 The monitors detect any loss of pressure from the set preset, so you are right that it means that you do not have to check pressures , but it does not absolve you from just forgetting and ignoring your tyres. 1 Quote Link to comment Share on other sites More sharing options...
E5GDM Posted February 27, 2016 Share Posted February 27, 2016 TIRE PRESSURE MONITORING SYSTEM WARNING The tire pressure monitoring system is not a substitute for manually checking your tire pressure. For more precise measurements, use a tire gauge to check your tire pressure at least once a month. Failure to properly maintain tire pressure can increase the risk of tire failure, loss of control, vehicle rollover and personal injury. Quote Link to comment Share on other sites More sharing options...
