Micro Posted May 18, 2016 Share Posted May 18, 2016 I just stuck 5050 led tape down each side under the plastic edges, wired up to the light cable with (gasp) scotchlocks (gasp). Obviously the tape is visible if you look, however you won't see it in normal use. Exceptional light to find what I want, day or night. Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted June 9, 2016 Author Share Posted June 9, 2016 So I wired in 2. Went to put in a 3rd because I didn't think it was bright enough and they all switched off. Could I have blown a fuse? Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted June 9, 2016 Share Posted June 9, 2016 So I wired in 2. Went to put in a 3rd because I didn't think it was bright enough and they all switched off. Could I have blown a fuse? The lights turn off after the boot has been open for either 10 or 20 minutes www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted June 9, 2016 Author Share Posted June 9, 2016 Yeah I checked that. They aren't turning back on and the light in the front now doesn't work. I'm pretty sure it's the fuse I just don't know what one it is Quote Link to comment Share on other sites More sharing options...
GingerFlame Posted June 9, 2016 Share Posted June 9, 2016 It'll be the fuse then, does the horn work? The fuse for the horn & interior lights were the same on the mk6 fiesta, dont know wether the focus is the same www.yorkshiredetailing.co.uk - approved resellers of the Highest quality detailing & Valeting supplies Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 9, 2016 Share Posted June 9, 2016 Fuse 104 on the board under the glovebox, 10A. Sent from my SM-G930F 1 Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted June 10, 2016 Author Share Posted June 10, 2016 6 hours ago, Stoney871 said: Fuse 104 on the board under the glovebox, 10A. Sent from my SM-G930F Where can I get new fuses? I'm assuming any car parts shop? Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted June 10, 2016 Share Posted June 10, 2016 You can usually get mini blades from just about anywhere, my Tesco even sells them. Maplin electronics, Halfords, most garages which sell accessories, eurocarparts, screw fix, B&Q. They aren't hard to find and if you have a bit of time you can also get them on eBay and amazon etc, they will be a lot cheaper on line, not that they are that expensive in the shops though. 2 Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted June 10, 2016 Author Share Posted June 10, 2016 What fuse is it? I can't see one labelled 104 Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 11, 2016 Share Posted June 11, 2016 Ah, The earlier fusebox. It's number 80, still 10A. 2 Quote Link to comment Share on other sites More sharing options...
Paddy.t Posted June 11, 2016 Share Posted June 11, 2016 Put my new boot light in last night. Its from a transit. Quote Link to comment Share on other sites More sharing options...
Jonanstee Posted June 11, 2016 Author Share Posted June 11, 2016 6 hours ago, Stoney871 said: Ah, The earlier fusebox. It's number 80, still 10A. Awesome thank you. Should I wore in the lights then put a new fuse in or do the fuse first then carry on doing the lights? Quote Link to comment Share on other sites More sharing options...
