LouisM Posted May 27, 2016 Share Posted May 27, 2016 Hi all Another dpf question! Instead of removal for the obvious benefits but obviously illegal and an mot fail etc. Has any one considered simply cutting it open and drilling a hole through it obviously not a full removal but a derestriction. Dpf is still in place, doing what it needs to do but not getting clogged due to exhaust gasses passing through the hole in it ? Just a tired late night thought Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 28, 2016 Share Posted May 28, 2016 Yeah I've seen it done, has all the cons of both leaving it and removing it with none of the pro's! It's about as useful as those EGR blanks with a hole in the middle. In fact I'm in the process of buying a car cheap that someone has done this to, thinking it would fix it lol. Invisibly gutting it is the only way to do it and pass MOTs. 2 Quote Link to comment Share on other sites More sharing options...
Dee_82 Posted May 28, 2016 Share Posted May 28, 2016 Why would you bother to go to the effort of cutting it open then only do half the job? 1 Quote Link to comment Share on other sites More sharing options...
BOF Posted May 28, 2016 Share Posted May 28, 2016 Well, that's a version of 'removal'. When people remove, they usually mean that the innards are removed but the casing is put back looking as original as possible (for, eg, MoT purposes). However, if the hole through the middle is big enough, then it is like having a hole and the DPF does nothing, and if it isn't it works like a slightly ineffectual DPF. Quote Link to comment Share on other sites More sharing options...
LouisM Posted May 28, 2016 Author Share Posted May 28, 2016 Just a thought, as I've been reading that in the event of a crash and the insurance cut it open for the precious metals in there etc, it's all still present minus an inch wide hole in the centre. What would be the consequences of removing it and not having a remap ? Would this cause high issues or ? Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted May 28, 2016 Share Posted May 28, 2016 If the insurance cut it open and find a 1" hole then your insurance is void due to changing emissions systems anyway so I don't see the point. A 1" hole wouldn't be anywhere near enough either, the core that's left will block up but it won't regen* due to not sensing the pressure. The 1" hole left would be a huge restriction then. *It will try to regen as a fail-safe eventually, but this will overheat the inside edges of the core and potentially break it, wouldn't risk that myself. If you don't have it mapped after full removal you risk overheating things and breaking the turbo. Quote Link to comment Share on other sites More sharing options...
