Support the club!
radio/cassette to cd/radio change
3 replies to this topic
#1 MarkyB75
MarkyB75
    Newbie
  • Pip
  • 1 posts
  • Ford Model: Fiesta
Posted 18 June 2008 - 07:58 PM
hi i have a 1996 fiesta 1.3, it currently has a ford 3000 radio/cassette. does anybody know if i can do a straight swap to a ford 6000 cd/radio or do i need anything extra? cheers
#2 gallagher
gallagher
    Newbie
  • Pip
  • 8 posts
  • Ford Model: mk 4 Fiesta
Posted 19 June 2008 - 02:06 PM
You might need a radio code.. but apart from that i think everythin is all the same..
need 2 double check as im not 100% sure!
#3 blakey260
blakey260
    Member
  • PipPip
  • 28 posts
  • Ford Model: Fiesta mk 4 1997
Posted 03 July 2008 - 08:53 PM
hi, with it being ford to ford you shouldn't need to change it really, you only really need to change it if its from a standard ford radio in the car to a after market radio, if you're doing that then you need to buy a harness adapter
#4 blakeyl
blakeyl
    Newbie
  • Pip
  • 5 posts
  • Ford Model: fiesta 1.25 ghia
Posted 10 July 2008 - 08:45 PM
yes just done it on my daughters 98 model fiesta. dont forget the radio code. you need either the radio removal prongers or four bits of welding rod or a chopped up wire coat hanger. The unit are swapped by cable only. DD din size. you should have no problem at all.
