FRAZDAZ Posted December 8, 2016 Share Posted December 8, 2016 Morning guys, Ran the wife to the airport this morning and when I went to open the boot it wouldn't open. Tried the key fob and then tried the boot itself no joy. Anyways on further inspection it looks as though she has put a jacket in the boot and part of the jacket (?zip) is stuck in the mechanism. (Based on what I could see from the inside). Question is, is it possible to open the boot from the inside? Fraser. Quote Link to comment Share on other sites More sharing options...
Flibbib Posted December 8, 2016 Share Posted December 8, 2016 I'm not sure on how to open it from the inside, but if it's a mk2 / 2.5 (might work on above) have you tried pressing the boot release on the key loads? Quote Link to comment Share on other sites More sharing options...
WES180 Posted December 8, 2016 Share Posted December 8, 2016 Just rag the jacket out, say the lock must have ripped it! Quote Link to comment Share on other sites More sharing options...
MrRedman Posted December 8, 2016 Share Posted December 8, 2016 Press the boot lid down near the lock whilst getting someone else to keep pressing the button 😂👍 1 Quote Link to comment Share on other sites More sharing options...
FRAZDAZ Posted December 8, 2016 Author Share Posted December 8, 2016 Thanks for the replies lads I will have a look tomorrow in the day light! If it was her jacket a would just yank it out, but unfortunately it's my jacket!! Lol 1 Quote Link to comment Share on other sites More sharing options...
WES180 Posted December 9, 2016 Share Posted December 9, 2016 7 hours ago, FRAZDAZ said: If it was her jacket a would just yank it out, but unfortunately it's my jacket!! Lol In that case then be very very careful with it! 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 9, 2016 Share Posted December 9, 2016 On Thursday, December 08, 2016 at 6:57 AM, FRAZDAZ said: Morning guys, Ran the wife to the airport this morning and when I went to open the boot it wouldn't open. Tried the key fob and then tried the boot itself no joy. Anyways on further inspection it looks as though she has put a jacket in the boot and part of the jacket (?zip) is stuck in the mechanism. (Based on what I could see from the inside). Question is, is it possible to open the boot from the inside? Fraser. Why didn't you put her in the passenger seat instead of the boot then 😁 Happened me twice, Easy fix with the correct Torx bit a TX40 is required along with a flat head screwdriver to get things sorted. the torx but is available from Halfords for a few pounds on its own not as part of a set as saw in image below You need to get in to the boot from the back seat, Temporarily remove two plastic caps from the lower boot door panel, Then stick the Torx TX40 in to both holes to unbolt the lower boot latch bracket from the chassis. Followed by popping out the four plastic retaining plugs which hold the lower boot panel in place then lift the boot door to freedom 🙌 followed by putting it all back together. I can add more detailed images if desired 1 Quote Link to comment Share on other sites More sharing options...
Flibbib Posted December 9, 2016 Share Posted December 9, 2016 4 hours ago, Lenny said: I can add more detailed images if desired That sub is perfect lol 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted December 9, 2016 Share Posted December 9, 2016 1 hour ago, Flibbib said: That sub is perfect lol Thanks Chris😅 Guide to Fitting Aftermarket headunit focus Mk2 & Mk2.5 Click Here Guide To fitting 10" HD Flip Down Monitor Focus Mk2 & Mk2.5 Click Here Custom 10" Sub enclosure & Amp panel Focus Mk2 & Mk2.5Click Here Quote Link to comment Share on other sites More sharing options...
