Devonboy Posted January 29, 2017 Share Posted January 29, 2017 Without stripping a door card off, can anyone tell me the size of the rear door Speakers. MkII Focus. Thanks in anticipation. 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 29, 2017 Share Posted January 29, 2017 4 hours ago, Devonboy said: Without stripping a door card off, can anyone tell me the size of the rear door speakers. MkII Focus. Thanks in anticipation. 6.5" 馃憤 don't forget to use aftermarket speaker adaptor rings aswell; there model specific and different set for front and rear doors.聽 聽 1 Quote Link to comment Share on other sites More sharing options...
Devonboy Posted January 30, 2017 Author Share Posted January 30, 2017 Thank you Lenny.聽 Did you mange to get all those bits back together again? 1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 30, 2017 Share Posted January 30, 2017 what size adapters for the rear doors Lenny please .got to do mine when weather gets better . 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 30, 2017 Share Posted January 30, 2017 1 hour ago, Devonboy said: Thank you Lenny.聽 Did you mange to get all those bits back together again? I sure聽did mate, not one screw or bolt left over thanks to聽the haynes manual and some zip lock bags keeps everything categorised聽馃槈 spent six months stock piling all the parts then took three days off work to strip install and rebuild. resulting in a 10" roof monitor, tv tuner, reverse camera, dual dash cam, two amplifiers, WiFi router, 10" sub enclosure, full speaker upgrade and a 1.0 Fared capacitor installed with factory finish. if interested to view; my build thread is here聽 Also full list of self created guides here: 聽 聽 Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 30, 2017 Share Posted January 30, 2017 50 minutes ago, mrmetallica said: what size adapters for the rear doors Lenny please .got to do mine when weather gets better . When removing the door cards I highly recommend replacing the plastic clips there available in packs of 20 on eBay 聽 聽 Focus 2005-2011 REAR speaker adaptors聽 http://www.ebay.co.uk/itm/261082740273 聽 聽 Focus 2005-2011 FRONT speaker adaptors聽 http://www.ebay.co.uk/itm/Ford-Focus-MK2-CMAX-Kuga-Speaker-Adaptor-Kit-Rings-Spacers-165mm-6-5-Front-Door/361155757527?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D20140122125356%26meid%3Dce9c5471b8ce45198713c5c89f5a8fdc%26pid%3D100005%26rk%3D3%26rkt%3D6%26sd%3D261082740273 聽 聽 The nuts bolts and washers are purchased separately from local DIY store size M6 x 20mm hex head bolts with nylon lock nuts聽 聽 You may also consider fitting some DEi Boom speaker baffles they enhance bass prevent panel rattle and protect speaker from moisture I have them fitted in all four doors. 聽 http://www.ebay.co.uk/itm/DEI-Boom-Mat-Speaker-Baffles-6-5-Round-pair/112246005736?_trksid=p2047675.c100005.m1851&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D2%26asc%3D20140122125356%26meid%3D103e98e106b046009b4f09dd9ec0880c%26pid%3D100005%26rk%3D1%26rkt%3D6%26sd%3D172475577743 聽 聽 聽 聽 聽 1 Quote Link to comment Share on other sites More sharing options...
mjt Posted January 30, 2017 Share Posted January 30, 2017 5 minutes ago, Lenny said: You may also consider fitting some DEi Boom speaker baffles they enhance bass prevent panel rattle and protect speaker from moisture I have them fitted in all four doors. Do they also help to reduce the booming that gets through my double-glazing 30 feet back from the road? 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 30, 2017 Share Posted January 30, 2017 31 minutes ago, mjt said: Do they also help to reduce the booming that gets through my double-glazing 30 feet back from the road? 馃槸well they do keep more of the bass inside the car but in fairness to generate resonating bass which travels that distance will be caused聽by an amplified sub in a聽sealed enclosure rather than a set of door Speakers. there are two types of sub enclosure this one in green is a 15" ported sub enclosure it throws out loud bass with very little resonance to surrounding area.馃檳 And this is a 10" sealed enclosure it puts very little bass out to be heard, it's purpose is to put out resonating bass which takes away your breath and tickles your grannys聽pacemaker at bus stop馃檴 1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 30, 2017 Share Posted January 30, 2017 1 hour ago, Lenny said: When removing the door cards I highly recommend replacing the plastic clips there available in packs of 20 on eBay 聽 聽 聽 Focus 2005-2011 REAR speaker adaptors聽 http://www.ebay.co.uk/itm/261082740273 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 聽 cheers lenny .was just going through your build thread but you answered before i got to the speaker mod you did . you sure put a lot of work in didnt you 1 Quote Link to comment Share on other sites More sharing options...
Lenny Posted January 30, 2017 Share Posted January 30, 2017 2 hours ago, mrmetallica said: cheers lenny .was just going through your build thread but you answered before i got to the speaker mod you did . you sure put a lot of work in didnt you Too much to be fair 馃榿 aside from the audio and entertaInment upgrades which keep the kids quiet; the rest of it was an enjoyable experience but have done it all once now; I wouldn't do it again. 1 Quote Link to comment Share on other sites More sharing options...
mrmetallica Posted January 30, 2017 Share Posted January 30, 2017 1 hour ago, Lenny said: Too much to be fair 馃榿 aside from the audio and entertaInment upgrades which keep the kids quiet; the rest of it was an enjoyable experience but have done it all once now; I wouldn't do it again. i bet the wallet and the misses are well pleased lol 1 Quote Link to comment Share on other sites More sharing options...
