Ian Lanc Posted April 11, 2017 Share Posted April 11, 2017 On the Titanium there's a 'one touch' switch for the driver-side window! This is built in the two switch box, Has anyone removed the standard switch off the passenger-side and then put the 'one touch' switch onto the passenger-side window ? Can this be done ? Thanks Quote Link to comment Share on other sites More sharing options...
MJNewton Posted April 11, 2017 Share Posted April 11, 2017 There is likely more to one-touch operation than just the switch - something needs to detect the window having closed to turn itself off. That's not to say replacing the switch wouldn't be all that's required though; the wiring and whatever module is responsible might already be there ready and waiting. Incidentally, is the passenger side switch definitely not one-touch also? I only ask because our Titanium (admittedly a 2013 model) has one-touch on both sides. 2 Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted April 12, 2017 Author Share Posted April 12, 2017 12 hours ago, MJNewton said: Incidentally, is the passenger side switch definitely not one-touch also? I only ask because our Titanium (admittedly a 2013 model) has one-touch on both sides. Ours is a 10 plate, tried numerous times to make it work as the drivers-side does but won't! Quote Link to comment Share on other sites More sharing options...
karl46 Posted April 12, 2017 Share Posted April 12, 2017 When you say that you have tried to make it work are you following the resetting procedure? Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted April 13, 2017 Author Share Posted April 13, 2017 22 hours ago, karl46 said: When you say that you have tried to make it work are you following the resetting procedure? Yeh I did the resetting procedure but alas the passenger-side only goes up & down by pressing the button constantly.....Seems stupid if you ask me! Quote Link to comment Share on other sites More sharing options...
MusicalChris Posted April 13, 2017 Share Posted April 13, 2017 I have a 2011 Zetec S and only works on Drivers side, i think this is normal as the Passenger switch only has one click down or up whereas the drivers side has two, first for manual and all the way down or up for auto Thats how i believe it works Chris Quote Link to comment Share on other sites More sharing options...
