BigKen65 Posted June 4, 2018 Share Posted June 4, 2018 The oil filler cap on my 2013 Focus TDi is stuck only moving slightly in either direction, is there a knack to taking it off or will it need replaced? Quote Link to comment Share on other sites More sharing options...
andypsp Posted June 4, 2018 Share Posted June 4, 2018 twist and pull up聽馃榿 Quote Link to comment Share on other sites More sharing options...
BigKen65 Posted June 4, 2018 Author Share Posted June 4, 2018 Yeah tried that, local garage tells me its common on these engines but I'm never convinced by Fast-fits pretending to be mechanics, its moving just a few mm right and left. Tried pushing down as I twist but wont budge.聽聽As its first time for me changing oil on this car wondered if there was a strange ritual that had to be performed with one leg in the air etc. Quote Link to comment Share on other sites More sharing options...
andypsp Posted June 4, 2018 Share Posted June 4, 2018 strange it`s not comeing off for you then. guess your local garage tried it aswell then and had no luck ? how long have you had the car for? Quote Link to comment Share on other sites More sharing options...
BigKen65 Posted June 5, 2018 Author Share Posted June 5, 2018 Just over a year, only had it open once and it opened easily. It will be my weekend project thanks for your comments.聽 Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted June 6, 2018 Share Posted June 6, 2018 Try it with a warm engine, the heat should help expand it slightly and make it easier. Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 6, 2018 Share Posted June 6, 2018 What you can to is bunch a teatowel long ways and loop it round the cap if you can. Collect the ends and twist them until it grips tightly on the cap, then use the teatowel as a wrench. I've done this a couple of times and works best when the cap has finger grips.聽 Quote Link to comment Share on other sites More sharing options...
Russ Posted June 15, 2018 Share Posted June 15, 2018 If you get the cap off or if/when you buy a new one smear some silicon grease around the seals on the cap and on the internal neck of the water tank and it鈥檒l never seize up again. Don鈥檛 ask ford for the grease as it鈥檒l cost an arm and a leg, get some from a shop like maplins for about 拢5 馃憤馃徏 Quote Link to comment Share on other sites More sharing options...
Phil21185 Posted June 16, 2018 Share Posted June 16, 2018 13 hours ago, Russ said: If you get the cap off or if/when you buy a new one smear some silicon grease around the seals on the cap and on the internal neck of the water tank and it鈥檒l never seize up again. Don鈥檛 ask ford for the grease as it鈥檒l cost an arm and a leg, get some from a shop like maplins for about 拢5 馃憤馃徏 Well, while Maplins is still open anyway... 1 Quote Link to comment Share on other sites More sharing options...
