Should my battery look like this?
Albert27
Serviced the mk3 1.6tdci today.  battery inspection revealed this (photo below). Is this normal? No issues from the battery to date.
Just now, iantt said:
Pity it's a 700amp battery, got a 590amp stop start efb sat in my garage. Unlucky.
I'm doing well out of your garage store (made use of the oil + filter + brake fluid today!) 😄 Is that stuff a sign it's on it's way out?
That's the battery acid leaking out, may be charging a bit to high a voltage occasionally or battery starting to become faulty. I would wash it off with boiling water then when it's dried off , take bracket off , remove battery and more boiling water in the battery tray to wash it away.  The bracket may have had the paint corroded off. Give it a spray with some paint . I would then refit battery and bracket. Just keep an eye on battery in a months time to see if it's furring up again. Then you may need a new battery.
I even did brake fluid change on my focus , thats the first in 5 years. Also full brake check/adjustment and air con service/recharge. Couldn't be bothered to do oil and filter today but was changed 4/5 months ago.
Thanks Ian, I will do that.  Hopefully I won't need a new one...£126!!  Ouch..bring back the mk2 battery!  We don't even use the start stop.
