ItsOnlyMe Posted May 23, 2019 Share Posted May 23, 2019 Hi, My passenger seat belt sticks when pulling it out. So the locking mechanism is working a bit too well. I have a feeling that the seat belt ball bearing is clogged and I would like to take it out and have a look. I understand that when taking the seat belt out, I need to disconnect the battery for a short time so as not to activate the air bags. When I reconnect the battery is there anything that I should be aware of. I have looked in my hand book and I have a keycode but no radio code. Will I need this? Any help is gratefully received. Many thanks, Kerrie. Quote Link to comment Share on other sites More sharing options...
liamstears Posted May 23, 2019 Share Posted May 23, 2019 Before going through all that effort try the simple fix, grab yourself some silicone spray, pull the seatbelt all the way out and give it a good spray all the way along the belt on both sides if possible and then retract it and pull it out a couple times This does the job most of the time Quote Link to comment Share on other sites More sharing options...
ItsOnlyMe Posted May 24, 2019 Author Share Posted May 24, 2019 On 5/23/2019 at 9:09 AM, liamstears said: Before going through all that effort try the simple fix, grab yourself some silicone spray, pull the seatbelt all the way out and give it a good spray all the way along the belt on both sides if possible and then retract it and pull it out a couple times This does the job most of the time Thank you, I will give that a go and will let you know how I get on. I really appreciate your reply. Thanks, Kerrie. Quote Link to comment Share on other sites More sharing options...
jsk Posted May 25, 2019 Share Posted May 25, 2019 My daughter had the same problem with the drivers seat belt. Advised her to pull it all the way out to see if it fixed it. Glad to say it did. Quote Link to comment Share on other sites More sharing options...
ItsOnlyMe Posted June 1, 2019 Author Share Posted June 1, 2019 thank you Liamstears, The silicone spray has worked a treat. The seat belt is now working properly. Many thanks, Kerrie. xx Quote Link to comment Share on other sites More sharing options...
