Hardwiring Galaxy S10 for Satnav use
Good morning,
Thanks for letting me join.
Has anyone used a hard wire kit to extend the power lead for their phone, so that it can be used as a Satnav?
Any help appreciated.
Cheers
Ian
You need a:
mini blade piggy back fuse adapter
10Amp mini blade fuse
12v USB power adapter (preferably a Q3.0)
15Amp cable
2 x Insulated spade crimp terminals (may come with usb socket)
8mm Crimp ring terminal for the earth feed to attach to a bolt somewhere.
USB cable of choice.
Then you just need to find a fuse which becomes live when the engine is operating.
Overall if you can purchase a dash cam hard wiring kit then your 95% of the way there.
Many thanks Lenny
6 minutes ago, ICMS304 said:
Many thanks Lenny
No problem,
Might give an idea for fitting to say; I've fitted a double USB socket inside the rear side of my glovebox, wired to an ignition live; one USB socket powers the dashcam system which is also hidden in the glovebox and the other USB socket has a cable connected for the TomTom Satnav, I just take it out through the glovebox door when required.
Guide here if interested to view it's on a mk2.5 focus;
