New car purchase
15 minutes ago, Bobr said:
I was a police driver though and we trained on both manual and automatic cars as we might have had to drive either on occasion.
👍 No worries, then! I was interested because, as I've mentioned elsewhere, I may have to make the switch myself eventually (dodgy toes on clutch foot). I'm ok with driving autos, but my Mrs has never driven one. She normally only drives her own car but may have to drive mine occasionally. I may have to persuade her to book a few lessons in an auto when the time comes!
  • Replies 140
  • Views 58.4k
  • Tried opening the car then taking the keys back in the house and going back to the car and, sure enough, the steering was locked. Fetched the keys and the steering stayed locked until I started the en
  • I'd like to publicly thank @Zico (Yaz) who has very kindly sent me a touch up set in Race Red that he had spare.   Wouldn't even let me pay for the postage.   I'm very much obliged to you Yaz.
  • Lol Ron.   I haven't got it yet.   I'll post a photo tomorrow.😊
First time I got into an auto car, Roger, the instructor told me to take my left shoe off.   It worked.
That's not bad advice. I once got into Mrs. TimST2's auto and pressed the brake pedal with my left foot as I got to the end of the driveway (no idea why). I nearly exited the car via the windscreen :laughing: :whistling:
The  first few weeks I had an Auto I had  problems when things got a bit busy at roundabouts or junctions I would go for the clutch when I would have been down changing on a manual and shooting myself through the screen as I left foot braked instead. Got used to it after a while. Now back on manual gearbox which I prefer unless I was doing a lot of driving in the city/town then I'd get an Auto.
oops wrong thread. 🙂
One thing I don't understand.   I've done a hell of a lot of research on this gearbox as I've never had a twin clutch auto before.   I understand that one clutch operates 1,3 &5 and the other 2,4 & 6.   But where does reverse come in?
No clue, this is my first one as well. 🙂
That's a good question, Bob!😀. Not certain on this, but I think I've seen somewhere that on a dual clutch box reverse would normally be on the same shaft as the "odd" gears (1,3,5).
1,3,5 & R
Thanks guys.   I've stripped and repaired gearboxes in the past (the distant past) but I don't think I'd like to tackle that one.😀
I’ve done the same, 3 times in about a minutes time, just couldn’t figure out how to adjust my body to acknowledge the fact there isn’t a clutch pedal to press, such a daft feeling
Found something that I think might be a bit odd.   I know that, when the gear lever is in Sport mode, you can change gear manually but I found that I can change gear manually when in Drive mode.   Is this normal?
Normally on the autos or dual clutch boxes I've driven, when manually selecting a gear while in D it quickly goes back to auto mode, if you do it in S it stays in the gear you select unless you select another yourself. I think it may mention this in the "Autocar" test I posted the link to.
Thanks Roger, I'll have a look.   In fact it did quickly revert to it's normal operation.
Yes, found it Roger.   Quote, 'In D, the gear you select manually defaults back to normal automatic mode quite soon. In S, the gear you select stays selected unless you move the rocker, or select D on the main lever.'
Mine does this too, in fact sometimes I bump the down button with my knee, which has scared the crap out of me haha.
Harking back to the tyre pressure problem earlier (20 psi in all tyres) it occured to me to wonder why the tyre pressure sensors didn't alert me to the problem.   So I reduced the pressure in one back tyre to 20 psi and drove round the block.   Nothing.   No alert at all.   Sandicliffe are collecting the car on 4th December to sort the problem out.
Did you check and see if it's enabled, I think all the settings are in the radio. It might just be disabled, maybe one of the sensors failed and in order to hide the error they just turned it off?
This might be a silly question, but did you reset the Base Pressure in the Information Screen when you pumped up the tyres to their correct pressure.
I have read elsewhere on this Forum that the warning comes when the pressure drops to below around 80% of the Set Pressure, so either it is not working or the car was set up incorrectly before you got it.
That is a very good point.
When I pumped the tyres up to their correct pressures I did reset the Pressure Monitor in the menu.
Going for my first long drive today; Nottingham to Wakefield and back.   Rather ,looking forward to seeing what the mpg will be.   It's 1 deg C and a bit foggy so will obviously be taking my time on the M1.
Have fun Bob m8, just remember low temps have a negative effect of MPG 😉
Have fun!
It was very foggy in patches and, on the way back was getting dark too.   I stuck to 60 mph and many others were doing the same.   Couldn't believe some idiots driving in fog with no lights on.   Overall average was 58.2 mpg in max temperature of 2 deg. C.   Quite pleased with that.   Still loving this gearbox.
