scrappydoo1982 Posted January 19, 2020 Share Posted January 19, 2020 Good afternoon So for 6 months my traction control light has been on my dash. With the mot coming up i decided to get new sensors. After fitting them the Abs light has come on and won't disappear. I put the old sensors back in and the lights still stay on (abs and traction control light). Any ideas at what it might be, or how to clear the lights... I've used my DTC to clear codes and there isn't any codes remaining. Forgot to mention, Its ford focus MK2 tdci Tia Quote Link to comment Share on other sites More sharing options...
isetta Posted January 19, 2020 Share Posted January 19, 2020 I am wondering if you are using a cheap generic fault code reader that does not read all modules on a Ford (eg. it reads the engine fault codes but not abs fault codes). Or the fault code reader is good but the software isn't good enough. Quote Link to comment Share on other sites More sharing options...
n_hudson Posted January 14, 2021 Share Posted January 14, 2021 On 1/19/2020 at 3:37 PM, scrappydoo1982 said: Good afternoon So for 6 months my traction control light has been on my dash. With the mot coming up i decided to get new sensors. After fitting them the Abs light has come on and won't disappear. I put the old sensors back in and the lights still stay on (abs and traction control light). Any ideas at what it might be, or how to clear the lights... I've used my DTC to clear codes and there isn't any codes remaining. Forgot to mention, Its ford focus MK2 tdci Tia Have you taken it for a drive? Disconnect battery maybe? (Should clear any fault codes until they come back) Are you sure the sensors are seated correctly and the plug connections aren't corroded? Did you have the codes read, did it point to a specific wheel? Quote Link to comment Share on other sites More sharing options...
