oopsitsbrokenagain Posted July 10, 2020 Share Posted July 10, 2020 I have a Mk2 2007 Focus LX 1.6 Petrol Duratec, as I've came into work this morning I've noticed an oil leak coming from the left side, I can see the trail following my cars path on the wet ground - I'll be having a closer look after I finish work, is there anything more common to leak on the left side that I should look out for? It was last serviced in February by the dealership I bought it from. Any pointers would be much appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
dezwez Posted July 10, 2020 Share Posted July 10, 2020 gearbox is on the left Quote Link to comment Share on other sites More sharing options...
F0CUE Posted July 10, 2020 Share Posted July 10, 2020 It will be the gearbox selector seal pretty easy to fix. Quote Link to comment Share on other sites More sharing options...
oopsitsbrokenagain Posted July 10, 2020 Author Share Posted July 10, 2020 42 minutes ago, dezwez said: gearbox is on the left Hoping its not the gearbox, but I'll have a look when I get it on my ramps at home. There's been no change in the way it drives. No clunky gear changes, no slipping, no juddering. I was thinking it could be steering rack seal - but I'll find out later. Quote Link to comment Share on other sites More sharing options...
oopsitsbrokenagain Posted July 10, 2020 Author Share Posted July 10, 2020 3 hours ago, oopsitsbrokenagain said: Hoping its not the gearbox, but I'll have a look when I get it on my ramps at home. There's been no change in the way it drives. No clunky gear changes, no slipping, no juddering. I was thinking it could be steering rack seal - but I'll find out later. I've had a look while I'm on lunch, found a sensor that the aluminium boss for it has snapped. As you can see in the photo. Does anybody know what sensor this is so I can order the correct one? Its on the front, at the left next to the plastic housing that covers the selector Quote Link to comment Share on other sites More sharing options...
TomsFocus Posted July 10, 2020 Share Posted July 10, 2020 9 minutes ago, oopsitsbrokenagain said: I've had a look while I'm on lunch, found a sensor that the aluminium boss for it has snapped. As you can see in the photo. Does anybody know what sensor this is so I can order the correct one? Its on the front, at the left next to the plastic housing that covers the selector That's the reverse light switch. Never seen one break like that before though! Quote Link to comment Share on other sites More sharing options...
dezwez Posted July 10, 2020 Share Posted July 10, 2020 I would get the oil in the box checked before if starts to cause damage to your gear box should be able to get a new switch off eBay Quote Link to comment Share on other sites More sharing options...
oopsitsbrokenagain Posted July 10, 2020 Author Share Posted July 10, 2020 1 hour ago, TomsFocus said: That's the reverse light switch. Never seen one break like that before though! It thankfully makes it an easy fix as the hex for the spanner is still on there - should take 10 mins to fit, plus some oil, so cheap and easy, can't complain...! 1 hour ago, dezwez said: I would get the oil in the box checked before if starts to cause damage to your gear box should be able to get a new switch off eBay Can get one at eurocarparts about 50 yds away from where I work, they've got one in stock for £13, so can't ask for easier than that 😄 Covering hole with latex glove and a cable tie to keep the crud out and the oil in until I get home - haven't lost too much I don't think. Thanks for your help guys, appreciate it Quote Link to comment Share on other sites More sharing options...
