oldboy22 Posted July 21, 2020 Share Posted July 21, 2020 Hi Do i need to remove the caliper carrier to get the disc of for renewal The two bolts holding the carrier are well rusted FIESTA 2005 1.25 CLIMATE 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted July 21, 2020 Share Posted July 21, 2020 yes try soaking the bolts with wd 40 Quote Link to comment Share on other sites More sharing options...
Cragrat Posted July 21, 2020 Share Posted July 21, 2020 Plus gas is much better Quote Link to comment Share on other sites More sharing options...
isetta Posted July 21, 2020 Share Posted July 21, 2020 If they are so tight the bolt heads rounded off, try hammering a smaller socket onto bolt head. This is where it can be handy to have old imperial size sockets some of which are in between metric sizes. On my sister’s 2004 fiesta I had to do this when changing her discs Quote Link to comment Share on other sites More sharing options...
oldboy22 Posted July 21, 2020 Author Share Posted July 21, 2020 I will soak. and yes i have old imperial sockets about Thanks for the advise 1 Quote Link to comment Share on other sites More sharing options...
dezwez Posted July 21, 2020 Share Posted July 21, 2020 should work out OK for you 😊 Quote Link to comment Share on other sites More sharing options...
Luke4efc Posted July 21, 2020 Share Posted July 21, 2020 6 point sockets instead of 12 point. Helps stop you rounding them off in the first place. Quote Link to comment Share on other sites More sharing options...
SparkEli Posted July 24, 2020 Share Posted July 24, 2020 When I was replacing the brake discs and pads I used one of these on the bolts as they had rounded badly. I got these from Screwfix and the socket worked perfectly. I used a hammer to make sure it wouldn't slip off and as you apply more pressure, to loosen the bolt, the sides of the socket dig into the the bolt and allows it to be removed. Make sure you buy replacement bolts. https://www.screwfix.com/p/erbauer-bolt-nut-remover-set-6-pcs/6083D?tc=QT7&ds_kid=92700055262507123&ds_rl=1244066&gclid=Cj0KCQjwjer4BRCZARIsABK4QeX9ckCd_O75ki4-CBsua5X8I9eKaSabsMo2BvPS8RB3srA77JS-HjgaAhUXEALw_wcB&gclsrc=aw.ds 1 Quote Link to comment Share on other sites More sharing options...
fiestaecoboostman Posted July 25, 2020 Share Posted July 25, 2020 8 hours ago, SparkEli said: When I was replacing the brake discs and pads I used one of these on the bolts as they had rounded badly. I got these from Screwfix and the socket worked perfectly. I used a hammer to make sure it wouldn't slip off and as you apply more pressure, to loosen the bolt, the sides of the socket dig into the the bolt and allows it to be removed. Make sure you buy replacement bolts. https://www.screwfix.com/p/erbauer-bolt-nut-remover-set-6-pcs/6083D?tc=QT7&ds_kid=92700055262507123&ds_rl=1244066&gclid=Cj0KCQjwjer4BRCZARIsABK4QeX9ckCd_O75ki4-CBsua5X8I9eKaSabsMo2BvPS8RB3srA77JS-HjgaAhUXEALw_wcB&gclsrc=aw.ds Could be worth there weight in gold, handy for anyone working on a vehicle. Quote Link to comment Share on other sites More sharing options...
