Mk4 FORScan Tweaks
I keep seeing a lot about codes but not finding any for my model of car. I want to add Climate control and Heated seats to sync 3 screen.
  • Replies 99
  • Views 63.5k
  • colinmcg71
    colinmcg71
    For anyone interested, here’s how the climate screens and home screen buttons look after enabling them on Sync 3.4. Dual zone working properly, driver and passenger buttons controlling their respectiv
  • colinmcg71
    colinmcg71
    No, it’s all the right way round on the Mk4 👍🏼
  • Research, research, research. If you rush at it you will brick modules.
The very first post in this thread by Colinmcg71 has a list of all the changes needed. Use the latest version of ForScan and just select what you want
Oh, I didn't realise I had to just change field. I've been looking into forscan and making changes and most of what I've seen is people using codes to make changes.
Am I best changing one at a time or doing them all in one go? One at a time seems safest.
You would be fine making all the climate changes in the APIM in one go, that’s what I did.
As @unofix said above definitely save your original configuration before making any changes.
There are two ways of doing the changes:
Module Configuration
Module Configuration (Asbuilt)
When you enter the modules in Asbuilt mode you will just see a bunch of codes
Splash screen change for example will be 7D0-02-01 you change the relevant code within the box to change the function - sometimes you change a 0 to a 1
In normal module configuration mode there is a list of functions with a drop box next to it
Example BCMii - LH Fog Lamp usage - The drop down box will list:
No Fogs or None
Fog Lamp only
Fog and cornering lamp
Fog and cornering and DRL
Fog and High Beam (Bambi Mode)
Fog as DRL etc etc
They're all dependant on functionality based on the vehicle
You just select the function you want, click OK
Then at the bottom of the screen select write all.
So you can go into APIM and do all the changes you want and then just click write all and it's done.
Just remember to save the standard configuration on your laptop (I title it "REG number/Module/Asbuilt) before you make any changes
Just make sure you have a good quality lead, Chinese ELM327 clones can cause issues an OBDLink EX is not expensive and very reliable.
Just research, research before going for it.
If anything goes wrong and you brick the module (e.g. because it can't understand what you've asked it to do) just reload the abuilt settings and click write all and it will come back.
If you get "operation failed" half way through then your lead is no good.
Some items require programming in Asbuilt mode only, using codes
E.G. Auto High Beam had to be coded (sometimes multiple times) in the following modules
BCM, IPC (Cluster), ABS, Camera Module and Power Steering module.
It took months trying to get it to work and it was only after finding out that it needed to be programmed in the power steering module that I finally got it to work
I hope I've made sense and this will help anyone.
Do NOT attempt to update firmware on any modules if you have a cheap lead, please, you will brick the module or worse, the car.
No Fogs or None
Fog Lamp only
Fog as DRL etc etc
Thanks, I only want to add the climate control for now, other changes may come later on.
I purchased the tunnelrat device as it was one recommend on here.
Just to add, APIM does not show up on Focus MK4 with some leads on Forscan, mine didn't show up until I bought the OBDLink EX.
If it doesn't show up, delete the profile, disconnect the battery for 10 mins and start again
On 4/13/2021 at 7:18 PM, colinmcg71 said:
Hi Rob,
Yeah, the heated windscreen is on the additional climate controls screen.
Looking at your profile shows you have a 2016 ST. Have you upgraded to Sync 3 yourself? If so the climate screen may not work correctly. I enabled it on my previous ST, a MY2016 and the dual zone controls on screen were reversed, driver button changed passenger side and vice versa.
Once travel is allowed I’d be happy to help.
Hey Colin..
Yeah upgraded to sync 3, the climate screen works the correct way for me, right hand controls driver side, left side controls passenger.. ..
That would be great mate,maybe a sunny daysummer  jaunt up to perthshire 🙂
19 minutes ago, Marker1971 said:
Hey Colin..
Yeah, that would be braw. You’re more than welcome 👍🏼
Added the climate control to sync 3. Very straightforward and worked first time.
Nice one, glad all went well.
Thanks for helpful post originally.
Don't suppose there's an option to completely disable collision assist?
  • 6 months later...
Can anyone advise me how to turn on OIL life MENU on Focus MK4 (2019) 1.5 Ecoblue using Forscan? Thanks!
  • 2 months later...
On 3/30/2021 at 1:23 PM, colinmcg71 said:
Yes, that can be disabled. The option is in the ACM. I quite like it though 😉
Thank you for this topic. Also my whole family thanks for turning off the engine's artificial sound :)
Hi guys. How can I shorten the time it takes to display information about the number of
seat belts fastened and fuel reserve? Can I turn off this information completely?
The warning is now a legal requirement under European laws and therefore can't be disabled.
But fuel reserve?
Would this be the same sound I get on my 2020 ST-Line ecoblue diesel? Sounds like the exhaust is blowing at ower sppeds or under acceleration? (Ford gge says its not leaking)
It could be. Next time you have FORScan connected load up the ACM and see if you have entries for 'Engine Sound Enhancement' and/or 'Software Engine Sound Enhancement' and whether or not they're enabled. Mine had both and they're now disabled.
for driving in London you can make it sound like a Taxi 🤣
Hi, thinking of getting Forscan for Android but without the ability to write / program anything is there really any point? Can you really not adjust anything with the Android version (eg. Set the battery charge threshold to 90%)?
You can not programme with a WiFi device.
That's what I thought - so all you can do with the Android version is view settings and diagnostic codes, and then clear diagnostic codes if they come up?
