Sync 3 F10 maps
Just appeared over at cyanlabs. Will download and have a look 😁
  • Replies 57
  • Views 27.1k
typical, just updated to f9...
Downloading now! Does it down grade software then upgrade it? You done it colin?
Ignore 🙂
Did it not give you the map option on sync updater site in cynalabs?
You done it colin?
Keep having the following appear, when I try to get in to CyanLabs:
Not yet, I’m going to do it this afternoon.
Yes, it will temporarily downgrade you to 3.3 so the reformat tool will work then leave you back on 3.4.20351.
Whole process should take 50-60 minutes depending on the speed of your USB drive.
Cheers col ! All this for a newer map!!😊
That’s a weird one, never seen that before.
Success 😀👍🏼39E54383-A472-4740-A4DD-4259C9838C69.thumb.jpeg.09e18becf4c2b73d3621df52a70cc562.jpeg
I'll wait and see if Alexp999 comes up with goods like he did with F9
Currently downloading, should be installed tonight or tomorrow if I get a bit of time and find my USB
I'll install tomoz not leaving car running for 50 ish mins lol
Quote
Surely, it should be possible just to update the maps withoutva reformat ?
IVSU versions now. System Voice has been updated along with Maps & Nav Voice.
Yes, it is. You could take the autoinstall file from F9 and edit it to reflect the F10 filenames. No need to reformat then but install would take around 2 hours.
That's an advert on top of page you need to scroll down fella.
Yes, I worked out it is Google placing the ads. I can clear it by clicking the little square box with the cross in it, and reporting as blocking part of the page. However, each time I click to a new link/page on CyanLabs, a different ad reappears. I just need to work out how to remove it permanently, when I get time, unless it's something CyanLabs has instigated, although Col had not seen it before. Meanwhile, I have managed to download the latest update.
Do you just need the link
https://cyanlabs.net/download/syn3updater-installer/?wpdmdl=24961&refresh=606431d8ecba61617179096
Download the installer and run.
The ignition has to be on, but the engine doesn't need to be running. I normally connect the car to a charger when doing the update, but you do have to babysit it otherwise the car will turn the ignition off after about 20 - 30 mins.
Snap
Anyone had F10 from Ford web?
or only available from cyan?
Only available through cyan pal. Think ford have only just released f9!🙄
