Joe678 Posted July 13, 2021 Share Posted July 13, 2021 Hi there, I bought my fiesta st mk7 last year and when i originally bought the car I was told I needed to get the front left tpms sensor replaced as the car would give a warning that the tyre sensor was not detected and to check manual plus to check tyre pressure. On top of this I’ve had to refill the air in tyres every week as they go down pretty quickly. After a while waiting for them send it out (they never did) I gave up and paid to have it replaced but with 4 new tyres as well as I changed to the slightly thicker 45 and after driving for about 30 minutes the message showed again so I contacted the garage and was told that maybe it needed to be resealed. I then noticed when refilling the tyres that the front drivers side and rear passenger were completely fine all the time and was just the front passenger and drivers rear letting out air. Yesterday I took the car to the garage and they replaced the front passenger tyre as it was a bit damaged and reseated the rear drivers side. Once again after driving the message reappeared so I check the tyres (again) and noticed it’s now only the drivers rear leaking air. I then checked all the valves to notice that the only tyre leaking air has a different valve to the other 3 tyres and looks pretty worn. I was wondering if this is a standard valve and not a tpms one I’ll post photos to see. The first photo is the one with air leaking out of and the 2nd photo is the one fitted on all the other 3 tyres which are completely fine Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted July 13, 2021 Share Posted July 13, 2021 Top picture is a standard valve - Bottom picture is a TPS. 1 Quote Link to comment Share on other sites More sharing options...
Joe678 Posted July 13, 2021 Author Share Posted July 13, 2021 6 minutes ago, Ian Lanc said: Top picture is a standard valve - Bottom picture is a TPS. Would that be why the car isn’t picking it up? Quote Link to comment Share on other sites More sharing options...
StephenFord Posted July 13, 2021 Share Posted July 13, 2021 1 hour ago, Joe678 said: Would that be why the car isn’t picking it up? eerrr... yes!! 🤣 2 Quote Link to comment Share on other sites More sharing options...
MarksST Posted July 13, 2021 Share Posted July 13, 2021 Both can be tpms valves, the sensor is fixed onto the valve with a screw. my metal valves have been ok but lots of ST owners have had them changed to rubber valves and some had the wheels replaced due to leaks. 1 Quote Link to comment Share on other sites More sharing options...
Lewie226 Posted July 14, 2021 Share Posted July 14, 2021 Also if the black one is TPMS it may not be compatible or the correct one for your car Quote Link to comment Share on other sites More sharing options...
unofix Posted July 14, 2021 Share Posted July 14, 2021 1 hour ago, Lewie226 said: the black one is TPMS it may not be compatible The black valve is just a regular basic tyre valve. Quote Link to comment Share on other sites More sharing options...
MarksST Posted July 14, 2021 Share Posted July 14, 2021 43 minutes ago, unofix said: The black valve is just a regular basic tyre valve. The tpms valves look like that as well, Quote Link to comment Share on other sites More sharing options...
isetta Posted July 14, 2021 Share Posted July 14, 2021 my 2015 fiesta has Tyre pressure warning valves but all of them are the black rubber type. The sensor is fixed to the bottom of the rubber part, inside the tyre so you can't see it. Form the outside they just look like the standard valves from years ago that had no sensors. So I think the visual difference is a red herring. if you want to check if it leaks around that valve take wheel off, pour soapy water around valve with wheel angled so it forms a puddle there and see if any bubbles appear, pull the valve stem about whilst you do this. 1 Quote Link to comment Share on other sites More sharing options...
Joe678 Posted July 14, 2021 Author Share Posted July 14, 2021 15 hours ago, MarksST said: Both can be tpms valves, the sensor is fixed onto the valve with a screw. my metal valves have been ok but lots of ST owners have had them changed to rubber valves and some had the wheels replaced due to leaks. Think the pressure is okay with the rubber valve now but the cars still saying the tpms isn’t detected so I’m just gonna guess it’s that one. Garage are gonna check it tomorrow Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted July 14, 2021 Share Posted July 14, 2021 18 hours ago, MarksST said: Both can be tpms valves, the sensor is fixed onto the valve with a screw. Didn't know that! 1 Quote Link to comment Share on other sites More sharing options...
JW1982 Posted July 14, 2021 Share Posted July 14, 2021 Original rubber Ford TPMS valves can be identified by the ridge just below the valve cap. Rubber non TPMS valves do not this ridge. 4 1 Quote Link to comment Share on other sites More sharing options...
FSTA1 Posted July 15, 2021 Share Posted July 15, 2021 Complicated things these TPMS sensors. If one is replaced it needs to be cloned against the old one or paired to the vehicle. This is done with a special gadget--not the OBS system or the vehicle computer settings-- and a sequence of ignition/clutch/brake pedal operations. Quote Link to comment Share on other sites More sharing options...
Lewie226 Posted July 15, 2021 Share Posted July 15, 2021 I thought it can possibly be paired on a 20 min p,us journey Quote Link to comment Share on other sites More sharing options...
Marky146 Posted July 29, 2021 Share Posted July 29, 2021 Here's my experience. I tok my ST alloys off, metal TPMS sensors fitted. Put on some steel wheels temporarily and every time I started I'd get warnings. I went through the menu and reset and about 15 minutes or so later the warnings would come back. Bought some ST-Line 17" alloys now and fitted them. The warnings haven't come back. Just saw this thread and went out and mine have the ridge as per above! SO yes, a long drive and the car will recognise and be happy with the replacement sensors it seems. I didn't realise these had them. I'll have to let a tyre down to double check but no idea how it knows which corner is which or why it's managed to pair with them. Certainly beats a ***** Renault, where you have to get the serial numbers and go into CLIP to register them. DEaler level only and about £100 just to code the Winter Wheels in! Robbing *****. 1 Quote Link to comment Share on other sites More sharing options...
