Adblue problem
Hi I have a code come up on my 2017 ranger 2.2 and I can’t delete it it’s to do with the adblue I think the code is p204f can any one help
Hello Mark, I'm not sure why you think P204F is a problem with adblue?
https://www.dtcdecode.com/Ford/P204F
Reductant system is the adblue system.
Probably the adblue injector blocked/not working . I assume you have topped up the adblue tank?
  • 1 year later...
Hi Did you fix the problem? I have the same issue, engine management light on and fault code P204F
  • 6 months later...
Hi Mark, i have the same issue and code P204F, i am struggling to find the cure, did you have any luck with yours ? Tommy.
  • 1 month later...
Hi...2021 Wildtrak and its full of ad blue but light won't come off and it's telling me to top up in 2k miles.. . Any idea
Needs plugging in to a diagnostic scanner to see what fault codes there are. That's basically the first step. Can be a multitude of reasons why the lights on.
As Ian has said you need to get the DTC's
