1.0 EcoBoost 'wet belt' issue
Just now, karlbbb said:
Just a small bump on this topic.
Recently picked up a '22 reg Focus Titanium Estate, with the 1.0 125 mHEV and 7-speed auto - will this be a timing chain? I understand it'll still be wet belt for the oil pump, but just for a little peace of mind I wanted to check on the main timing belt/chain situation.
All mHEV and all Mk4 Focus are timing chain.
  • Replies 251
  • Views 191.8k
  • And I want to thank you guys for listening to my rants. Due to the fact we are now selling both of our Fords after this debacle - it means I will no longer be a member of the Ford Owners Club. It
  • Well this is my final update on what has been a very long and winding road.... As normal, even at the last minute it didn't go well. The car was due to be collected on Friday, and when we got the
  • Eric Bloodaxe
    Eric Bloodaxe
    Yes, quite right, Tom. I feel fortunate that, at the time in my life when I was so skint the only way I could afford to run a car was diy, that (a) cars were relatively easy to understand and work on
Brilliant, thanks very much.
Yes, you still need to make sure the correct oil is used and no flushing or the oil pump belt will fail
... and one good example when the correct oil is used at correct service intervals!
I find it hard to accept that the photo shows a true representation.
If anyone were to look down my engine front cover towards the crank right now they would be amazed by the amount of debris from the belt.
Belt one year old, less than 5000 miles on it.
Do we seriously believe it's because I used Petronas oil (to the correct spec) instead of Castrol?
Ray, this video is from the Bulgarian Ford forum /I am Bulgarian/. The car is Ford Focus C Max with 1.0 Ecoboost owned from new and as the owner was concerned about the belt condition (based on all these horror stories) he simply decided to check the belts and oil pump condition. I just wanted to share it as a good example and to show that not all Ecoboost engines are just scrap. Since the car is owned form new and has been always serviced with original oil recommended by Ford he kept telling us that with the recommended oil problems should not be expected. Probably that's the reason why he posted that photo. Once again, apologize for my English!
P.S. By the way I also understood that since 2017 Ford has changed to an upgraded and improved version of the original Dayco belts. The part № of the new belt is 2260991 /16 mm/ and he replaced the previous versions 1807611 /16 mm/  and 1760650 /18 mm/. I also found the Ford switched from Dayco to Contitech belts and most probably the new belt is Contitech CT1211 /not confirmed!/. Some more info although not for Ecoboost engines Continental Launches New Timing Belt for Special Citroen and Peugeot Engines - Continental AG
Impossible. There are no 100,000km Ecoboosts out there as they will all without exception have had a failed belt 😉
Belt one year old, less than 5000 miles on it?
How? Are you referring to the aux belt, as the wet belt isn't visible without taking most of the timing case off.
Here you can find the new belt /below/ and the older one /above/...
Of course I have the the camshaft cover off. One can easily see down into the timing case. There is debris everywhere. I won't comment any further.
Take exception to that comment! Mine has 97,000kms & counting!
Partner's fiesta has 78k miles so around 126000km
No issues so far?
It’s a timing chain for MHEV’s.
Oops didn’t see others had commented!
7 hours ago, Hackney said:
No issues so far?
Nope, just gets service around June them an oil change in winter. Had 1 rear spring and a set of front pads. Registered 2016.
I try to change my oil roughly twice a year.If the belt does go,so does the car.It’s just not worth forking the money out to have it repaired, we will just go back down to one vehicle, that being our fantastic Honda HRV Hybrid.Ford can keep their cars. Just to clarify the mileage I quoted is 97,000 kilometres.
  • 2 months later...
I have a 2016 ecosport with 75k miles and now with crank shaft fault code(P0016:78-EC and P132B:21-6C)after taking it to my local garage (non Ford), they said it’s a very common fault and gave 3 options:
1 - replace wet belt with specialist tools and extensive labour £2K
2 - replacement engine £3k ish
3 - his recommendation- get rid
Also talking with another mechanic, he suggested
1 - contacting Ford Uk, suggesting it’s a common fault but highly unlikely they will won’t to know!
2 - replacing the oil pump to help remove the fault code and then trade in.
what ever the option, it’s going to cost….. any advice is appreciated, cheers
1 - Contact Ford. Good luck with that, they get hundreds of similar reports each week. Your car is 7 years old. Does it have a full Ford service history ?They will not be in the slightest interested.
2 -  In order to replace the oil pump you would have to do the exact same work as replacing the cambelt.
Take the car to a Ford garage and ask them what the recommend. If they say it needs a new engine then you can always shop around and even get a quote from PumaSpeed.
I thought this too until recently.  Turns out it is possible to remove the oil pump by just removing the sump and then sliding the pump out of the belt (as opposed to sliding the belt off the pump).  You can then clean or replace the pump without having to touch the cambelt.
I must admit, I don't see the point in replacing the pump if the wetbelt is known to be degrading - better off just cleaning the old one.
Of course, there is a moral consideration by just masking an issue which will cause the next owner major issues, but that's not for us to decide.
Ecopro in Lincoln would get my vote if your close.
Agree. Going right back to the beginning with my Ecoboom, this is what a local garage did to (what was then) my daughters car.
Mechanic dropped the sump, fitted a very expensive new pump and oil control valve and told her it would be ok.
The regulars here know the rest.
Add one more wet belt failure to the listings. I have had my 2017 C-Max Titanium from new and found some months later the paperwork did not show the service interval. I called the dealership and was told to call the Ford Customer service centre who, after a few moments on hold told me that the interval was 15000 miles or 12 months so that is what I stuck to. The dealership never queried it and I took out a service plan which again did not specify anything different. All was well until Covid came along and servicing was only given to critical workers so the car went 14 months between services and was booked in as soon as was possible. At 87k miles (the last service) I found my service book had gone missing when I got home and checked the documents in the wallet where I keep the receipts/ manual etc. I called the dealership and they said the booklet was not there but gave me a new history from their files. Come 100k miles I found there was a wait of several weeks to get the car serviced and booked it in at the earliest possible. At 104k miles I decided to push for an earlier servicing and was given a date a few days ahead at another local dealership which I took. On the way the oil pressure light flickered and I stopped the engine and coasted to a nearby layby and got the car to the dealership via the AA. The following day I was told the engine is needing replacement plus turbo and ancillaries. I was asked for my V5 as the dealership were contacting Ford re some help with the engine change. The V5 was beking the service book in the wallet but it also could not be found. I ordered a replacement to be told minutes later that it had been found in the back of the wallet which had been split open....very strange. Five weeks later and £6500 later the car was returned to me. Ford would not help and my "Poor service history" was the reason, yet it was taken to the dealership every service on a pre-paid service contract where no mileages were stated nor recorded. Needless to say this was my 9th and likely the last Ford I shall own. Had I known of the Ecoboost engine issues I would have steered well clear as it has elements of flawed design throughout its history. How can an item be given a 150000 mile/ 10 year life yet fails at much lower periods. Can owners be expected to leave their car at home because they cannot get the car serviced for several weeks and would go over 12500 miles?. Modern synthetic oils have vastly improved properties over non synthetic oils and one would believe there would be more tolerance available, not a reduction. I was later told it is 12500 miles + 500 miles. When my commute to work was 250 miles a day (5000 per month) the numbers become laughable and am thankful I am now retired as a service every 10 weeks would have been impossible to achieve.
