hondansxr Posted May 26, 2022 Share Posted May 26, 2022 as above hi at my whits end ..2010 zetec s only done 64k miles , drives fine until it just starts to slow down on its own (like someone has turned the fuel off) then it just goes back to normal .It is sooo random, cambelt service plugs filters & leads 1 new fuel pump xx (no difference) 2 new throtle pedal .xx 3 new throttle body xx 4 sent ecu of to be tested the exchange unit that was supplied also xx so back to original 5 checked fuel lines for blockage xx 6 air flow meter had diagnostic on no faults logged also when it happens the trottle pedal / acc position does not change .. just dont get how it can do 20 miles no issue then bam then then it carries on ... i have tried to replicate going round islands x2 but no difference ... HELP Quote Link to comment Share on other sites More sharing options...
dezwez Posted May 26, 2022 Share Posted May 26, 2022 It may be the instrument panel the solder get weak then you get all sorts of problems when it does it again slap the top of the dash board above the instrument panel see if it makes it better 👍 2 Quote Link to comment Share on other sites More sharing options...
RL123 Posted May 26, 2022 Share Posted May 26, 2022 What diagnostics? There are cheap code readers and interfaces that won’t read all codes and not both can busses. people on here recommend forscan software and a good elm327 lead with switching. 1 Quote Link to comment Share on other sites More sharing options...
unofix Posted May 26, 2022 Share Posted May 26, 2022 4 hours ago, hondansxr said: had diagnostic on no faults logged also when it happens There are only two sure ways to check and read all Ford specific DTC's (1) take car to Ford main dealer, pay very large amount of money (plus a kidney) and they will use there special Ford code reader OR (2) Use FORScan software (it's Free) and a good ELM327 (modified) lead or better still use the new 'vLinker FS' lead, and you will have a bit of kit that is almost as good as the main dealers. download FORScan: https://forscan.org/download.html ELM327 (modified lead): https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx new 'vLinker FS' lead: https://www.bmdiag.co.uk/forscan-diagnostic-cable-for-ford-vgate-vlinker-fs 2 Quote Link to comment Share on other sites More sharing options...
Eric Bloodaxe Posted May 27, 2022 Share Posted May 27, 2022 Probably of no help here, but once had exactly the same issue with my Mrs's old Astra, many years back. This turned out to be a sand-like material in the bottom of the carburettor float chamber (I said it was many years back! 😀) being sucked up into the jets in some conditions. I assumed it had got there via a dirty tank in a filling station. Obviously we are talking fuel injection with the Z-S, but is there anything not yet checked which could harbour similar debris, I wonder? Quote Link to comment Share on other sites More sharing options...
Neb_engineer Posted May 27, 2022 Share Posted May 27, 2022 4 hours ago, Eric Bloodaxe said: Probably of no help here, but once had exactly the same issue with my Mrs's old Astra, many years back. This turned out to be a sand-like material in the bottom of the carburettor float chamber (I said it was many years back! 😀) being sucked up into the jets in some conditions. I assumed it had got there via a dirty tank in a filling station. Obviously we are talking fuel injection with the Z-S, but is there anything not yet checked which could harbour similar debris, I wonder? It would have been caught in the intank fuel filter, clearly not an issue as that would have been replaced when the pump was Quote Link to comment Share on other sites More sharing options...
hondansxr Posted May 27, 2022 Author Share Posted May 27, 2022 On 5/26/2022 at 11:02 PM, unofix said: There are only two sure ways to check and read all Ford specific DTC's (1) take car to Ford main dealer, pay very large amount of money (plus a kidney) and they will use there special Ford code reader OR (2) Use FORScan software (it's Free) and a good ELM327 (modified) lead or better still use the new 'vLinker FS' lead, and you will have a bit of kit that is almost as good as the main dealers. download FORScan: https://forscan.org/download.html ELM327 (modified lead): https://tunnelrat-electronics.fwscart.com/USB_Modified_with_switch_ELM327/p4541936_17045457.aspx new 'vLinker FS' lead: https://www.bmdiag.co.uk/forscan-diagnostic-cable-for-ford-vgate-vlinker-fs its been to ford no fault codes stored .... Quote Link to comment Share on other sites More sharing options...
hondansxr Posted May 27, 2022 Author Share Posted May 27, 2022 so i think its solved , had a think about what will cause fule cut off and spark cut ... crank sensor !!! so for £11.44 i took a punt , 35 miles later the car seemed smoother and no cutting out ... should have realised not all sensors give faults ... hope this helps so,meelse one day . 2 Quote Link to comment Share on other sites More sharing options...
