2010 1.6 tdci. Still has fault.
No I didn't. Even worse now.
  • Replies 52
  • Views 11.6k
  • LarsfromNorway
    LarsfromNorway
    My 2008 1.6 tdci acted a bit like yours, but around 2000 rpm. When doing about 50 mph in 4th or 5th it started to stutter and jerk, and also when flooring it between 3-4000 rpm, then it was full cut f
  • Lumpy cold start with white smoke is probably just a weak glowplug, wouldn't be too bothered by that myself. Injectors would be my best guess for lumpy cruising thoigh.  I can't remember your las
  • LarsfromNorway
    LarsfromNorway
    I think i mentioned the wrong part in my post above, this is the actual part that went bad on mine:  https://www.diesel-injectors.co.uk/product/genuine-bosch-fuel-control-valve-0928400607-0928400
Have you thought of doing a egr delete?
I have, however I'm leaning towards a software issue that was ingrained into lots of them from the factory. Mine is at 194K so not to worried now lol. Have you the same issue?
