P0106
Sean, I suggest you RTFP.
  • Replies 50
  • Views 17.8k
  • Have you had a look at the Live Data for the MAP, Boost Pressure and Barometric Pressure with the Ignition on to see if they are all reading Atmospheric Pressure.
  • I doubt it, but as per one of my earlier posts if you bring up RPM when cranking you will see if the PCM is getting a signal that the Engine is turning over. That is something that I do as a matter of
  • Yes Tizer, your earlier post about RPM; I wish I had concentrated on it back then...... For the brief second the car cranks, the RPM PID is zero.  I disconnect the crank sensor and removed it.  N
