Windscreen washer problem
dartiss
 Share
I've had my (second) Puma for just over a year now.
In recent weeks I've noticed that the passenger side windscreen washer isn't working very well. I got my wife to help me out today, so I could watch is closer up and see what's happening... water is coming out but just not at the same pressure as the driver side. As a result, it's barely hitting the windscreen (a light spray at the very, very bottom - most of it is just going into the gutter).
I've read a few posts on various forums, and seem some video, on this subject, but most of it is around adjustment (which this doesn't need). I can't see any obvious blockage, but wondering if anybody had any suggestions (which doesn't involve taking half the car apart)?
Link to comment
There is no adjustment on the mist jets. They are generally a pain in the ar5e and get partly blocked with the slightest bit of dirt in the screenwash fluid.
You will have to remove the jet assembly from the car to clean it. Run it under the hot tap while using an old toothbrush in a stabbing motion. Try to get the bristles to poke in to the front of the mist jet and back flush the dirt out.
  • Like 1
Link to comment
1 hour ago, Rizmo said:
Could it be an air lock
Easy to check, pull the hose off the nozzle, and hit the washer button. See if water shoots out the hose... If it does, @unofix suggestion above is good. As well as a 'brush' to try and clear blockage, the old fashioned method it to put stem of nozzle in your mouth and blow as hard as you can! (Of course, if you've access to an air compressor, that'll work too LOL)
  • Like 1
Link to comment
1 minute ago, dartiss said:
FixedThe washer jet pipe had come partially detached.
No doubt discovered when you went to pull it off to check water flow 🤣
Link to comment
  Only 75 emoji are allowed.
 Share
  • Create New...
Forums
News
Membership
