Key issues
mizz239
Hi peeps...OK so I have a problem with my spare key.  I have done the 4 turn ignition trick and the key fob locks and unlocks the doors, but the key, after putting in the ignition,  doesn't start the car and the red light on dashboard flashes....any ideas..thanks beforehand..
Transponder chip has not been programmed in to the car.
Is your car a 2006 model ? If so you might be able to programme the transponder in using FORScan (Licensed version £12) and a vLinker FS lead (£32).
As Uno says or find someone local with the kit.
Thanks I'll give that a try..it is the 2006 model focus, is the forscan through obd connector?
15 minutes ago, mizz239 said:
... is the forscan through obd connector?
Yes...
instead of the v-linker you could get away with using a modified ELM cable on a 2006
You could get lucky and try the 'official' Ford procedure... (You'll need 2 x original keys)
Thanks, will it work if I only have 1 x original key and another key (which is the one that doesn't start the car, but does open doors)?
100% not !!
It only works if you have two separately coded keys that both can start the car. It won't even work if you have two keys that start the car but they are clones of each other.
That procedure was only intended to be used if you had two original keys that both start the engine.
FORscan is your best and cheapest option, you can wipe and recode up to 3 keys from memory via the PAT's system
Just a small word of caution. You can only do that on vehicles up to 2013. Sadly after that point in time FORScan is unable to programme the vehicle with new keys, due to the feature being removed for security reasons.
  • Like 2
Thanks as mines 2006 I should be having this issue then..
should'nt
  • Insurance
  • Support
