2019 ford galaxy heated front screen not working
The battery SOC probably increased on the drive over.
The heated screen will melt ice when it's working.  It won't melt a thick layer of snow.
  • Replies 53
  • Views 5.3k
  • StephenFord
    StephenFord
    With all respect to all suggestion 'fixes', the car still has some warranty left on it. The owner should not be pottering around with relays etc. Just take it back to the darn garage and get them
  • I can certainly confirm that on the two Ford Galaxy's that I owned (twenty years ago), the heated front screens did not work if the outside temperature was above 7oC As for more recent Ford's I s
  • Has this heated front screen ever worked in the time you have owned the vehicle ? Has the windscreen ever been replaced in the past ? The left and right side of the front screens are eff
2 hours ago, StephenFord said:
when I had a heated screen (many years ago) it would clear an iced up screen in 30 seconds to 2 minutes, barely any time at all.
That was in the days of pre-GT
Since we are the verge of a global melt down they've had to reduce the heat by 90% 🤣
 I’m going to try and get the charging target set to 90 - 95 percent as suggest so hopefully then I may see an improvement
Thanks again for all the comments guys
