thevegman Posted August 27, 2011 Share Posted August 27, 2011 Good Morning all, Does any one know how to get past the "enter pin" screen on the touch screen sat nav fitted to my 54 plate ghia x mondeo...used up all my chances(had the wrong pin)..it then went to wait 30 mins..and now displays enter pin..its like i'm locked out, but no locked out screen? main dealer says it broken!! Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 27, 2011 Share Posted August 27, 2011 Good Morning all, Does any one know how to get past the "enter pin" screen on the touch screen sat nav fitted to my 54 plate ghia x mondeo...used up all my chances(had the wrong pin)..it then went to wait 30 mins..and now displays enter pin..its like i'm locked out, but no locked out screen? main dealer says it broken!! Can’t help you mate, But how knowledgeable of The Ford dealers to quickly identify the problem Quote Link to comment Share on other sites More sharing options...
Preee Posted August 27, 2011 Share Posted August 27, 2011 What is your BP code and s/n codes.You will need to remove your unit to get the serial codes printed either on the case or sticker. Quote Link to comment Share on other sites More sharing options...
thevegman Posted August 27, 2011 Author Share Posted August 27, 2011 I'll try to get the info req from the unit...will need to visit e bay to get some keys though..let ya know asap.. Thanks to all for your responses. Quote Link to comment Share on other sites More sharing options...
Twonker Posted August 31, 2011 Share Posted August 31, 2011 Sorry mate, this is a bad sign, I recommend a visit to the local car parts shop and get a roll of two inch wide masking tape and some blu tac, Remove the unit from the dash, disconnect all cables, make sure your ignition is off. you now need a metal disk about 1 inch across, a 10p coin is about the right size next you need to earth out the unit, this is where the masking tape comes in to its own, before you do that, take the metal disk ( the 10p coin ) and put the coin secure to the top of the unit with the blu tac, next you need to take the unit out to a anodised structure, I can recommend a bus shelter, use the masking tape to make a good connection to the upright post. then go to Halfords and buy a satnav..... Look on the bright side, if anyone in the bus shelter should finds it, well at least they have found 10p Regards, The Twonk 2 Quote Link to comment Share on other sites More sharing options...
Lenny Posted August 31, 2011 Share Posted August 31, 2011 Look on the bright side, if anyone in the bus shelter should finds it, well at least they have found 10p Regards, The Twonk Quality Advise their and for everything else theirs MasterCard :lol: Try www.caraudiodirect.co.uk can be cheap. 1 Quote Link to comment Share on other sites More sharing options...
thevegman Posted August 31, 2011 Author Share Posted August 31, 2011 Still awaiting delivery of the the keys to remove the unit to get the info required...so won't be looking for a bus shelter just yet..just trying to avoid the £2300 quid quote for a new one.. Quote Link to comment Share on other sites More sharing options...
thevegman Posted September 2, 2011 Author Share Posted September 2, 2011 Hi all once again, Keys came to enable me to remove my sat nav....details from the unit are:- S/No 48001289 MOO6499 SERIAL CVM 127625 FD13 2N MECHANISM PART NO VP3M5F-18C 821-DG VISTEON 5ST1813988 AC CD132MOD 19/1/2005 JAN10 Thanks once again for any help anyone can give.. Quote Link to comment Share on other sites More sharing options...
thevegman Posted September 2, 2011 Author Share Posted September 2, 2011 What is your BP code and s/n codes.You will need to remove your unit to get the serial codes printed either on the case or sticker. Details you need below ...Thanks Quote Link to comment Share on other sites More sharing options...
Preee Posted September 2, 2011 Share Posted September 2, 2011 using the code MOO6499 On the normal keygen returns this code 3351 If it does not work then there are online websites that can get you the code or you can take that info to a dealer and ask them for the correct code. let me kow if it works Quote Link to comment Share on other sites More sharing options...
thevegman Posted September 2, 2011 Author Share Posted September 2, 2011 using the code MOO6499 On the normal keygen returns this code 3351 If it does not work then there are online websites that can get you the code or you can take that info to a dealer and ask them for the correct code. let me kow if it works No joy i'm afraid...after pressing enter it just goes straight back to to the same screen showing enter pin...it seems to be stuck on this screen... Quote Link to comment Share on other sites More sharing options...
Preee Posted September 2, 2011 Share Posted September 2, 2011 Somewhere on the net , is a way to give you 3 more chances to input the code i'll have a search for that, You say its a Touch screen is it an nx model satnav? Quote Link to comment Share on other sites More sharing options...
thevegman Posted September 2, 2011 Author Share Posted September 2, 2011 Somewhere on the net , is a way to give you 3 more chances to input the code i'll have a search for that, You say its a Touch screen is it an nx model satnav? Sorry mate don't know...I'm useless Quote Link to comment Share on other sites More sharing options...
Preee Posted September 2, 2011 Share Posted September 2, 2011 Sorry mate don't know...I'm useless Armed with the sticker info above you should be able to go to a Decent Ford Dealer with your VIN number and either get the code or they should be able to reset it. does it say lock10 or lock 13 on it and exactly how manty attempts did you try on it.? Quote Link to comment Share on other sites More sharing options...
thevegman Posted September 2, 2011 Author Share Posted September 2, 2011 Armed with the sticker info above you should be able to go to a Decent Ford Dealer with your VIN number and either get the code or they should be able to reset it. does it say lock10 or lock 13 on it and exactly how manty attempts did you try on it.? It doesn't say either on screen...just enter pin... Tried dozens of times by now..lost count being honest. Quote Link to comment Share on other sites More sharing options...
Preee Posted September 2, 2011 Share Posted September 2, 2011 Ford might be your only answer or a radio decoding company Quote Link to comment Share on other sites More sharing options...
thevegman Posted September 2, 2011 Author Share Posted September 2, 2011 Ford might be your only answer or a radio decoding company Thanks for all your efforts... Quote Link to comment Share on other sites More sharing options...
Preee Posted September 2, 2011 Share Posted September 2, 2011 according to that serial number its 3351 , have you tried putting it in the garage and leaving it switched on all night , incase its time locked . Quote Link to comment Share on other sites More sharing options...
thevegman Posted September 2, 2011 Author Share Posted September 2, 2011 according to that serial number its 3351 , have you tried putting it in the garage and leaving it switched on all night , incase its time locked . give that a try and let ya know. Quote Link to comment Share on other sites More sharing options...
thevegman Posted September 4, 2011 Author Share Posted September 4, 2011 give that a try and let ya know. No luck mate...so its back to the drawing board or a specialist decoder..or have to try another Ford dealer. but thanks for all yr efforts. Quote Link to comment Share on other sites More sharing options...
vicmc Posted May 6, 2015 Share Posted May 6, 2015 I've got the same problem, Ford took radio out, got code from Ford HQ but unit says incorrect code. Did you have any joy? Quote Link to comment Share on other sites More sharing options...
Ashleicester Posted June 3, 2020 Share Posted June 3, 2020 Hi - I have the same problem ... has anybody found a fix Quote Link to comment Share on other sites More sharing options...
Stoney871 Posted June 3, 2020 Share Posted June 3, 2020 Sent from my SM-G965F using Tapatalk Quote Link to comment Share on other sites More sharing options...
