ramps Posted October 8, 2011 Share Posted October 8, 2011 Hi has anyone else found that the jacking point covers seem to just fall off the side skirts or they seem to be helped off lost my rear near side one last night anyone know the price of a replacement thanks Quote Link to comment Share on other sites More sharing options...
Liverpool-S Posted October 8, 2011 Share Posted October 8, 2011 yes mate i had this with mine, it always seemed to be in the wind when it would fall off on the motoway and i would have to pull over otherwise i probably would loose it. The solution to this, but check first... are your sideskirts loose at the back. this was causing the problem with mine, as the sideskirts were not attached properly so the wind on the motoway was causing the sideskirt to blow therefore making the cap come loose and fall out. I gunned grip adhisive behind the sideskirt in the wheel arch area, and problem solved! Hope this helps. Quote Link to comment Share on other sites More sharing options...
iNath Posted October 8, 2011 Share Posted October 8, 2011 Mine have never fallen off, in fact they're quite difficult to remove when you do want them off! Mine also have plastic cables so when they come off they dangle - does yours have them? Part numbers & prices here Quote Link to comment Share on other sites More sharing options...
ramps Posted October 9, 2011 Author Share Posted October 9, 2011 Mine have never fallen off, in fact they're quite difficult to remove when you do want them off! Mine also have plastic cables so when they come off they dangle - does yours have them? Part numbers & prices here yes mine have the plastic ties on bit i think someone must have lost their own and to a fancy to mine will have to go to the dealers and check out the prices Quote Link to comment Share on other sites More sharing options...
KeithC Posted October 9, 2011 Share Posted October 9, 2011 Mine have never fallen off, in fact they're quite difficult to remove when you do want them off! Mine also have plastic cables so when they come off they dangle - does yours have them? Part numbers & prices here This. They are a right pain in the !Removed! to get off so i doubt mine would ever fall off. I get the impression the reason why they may fall off is that they haven't been replaced properly when removed. Quote Link to comment Share on other sites More sharing options...
ramps Posted October 11, 2011 Author Share Posted October 11, 2011 This. They are a right pain in the !Removed! to get off so i doubt mine would ever fall off. I get the impression the reason why they may fall off is that they haven't been replaced properly when removed. They have never been off before as i used a trolley jack when working on the car emailed fordpartsuk they wanted £36 for a replacement checked out the local dealers they wanted £22.49 so it was ordered from there straight away 1 Quote Link to comment Share on other sites More sharing options...
KeithC Posted October 11, 2011 Share Posted October 11, 2011 They have never been off before as i used a trolley jack when working on the car emailed fordpartsuk they wanted £36 for a replacement checked out the local dealers they wanted £22.49 so it was ordered from there straight away Somebody must have robbed them as mentioned earlier. Quote Link to comment Share on other sites More sharing options...
