Igorius Posted June 13, 2012 Share Posted June 13, 2012 My passenger side carpet is damp and smells. I guess the previous owner had broken/weakened seal of the cabin filter cowl and some water leaked in the cabin. I want to remove, wash and dry the carpet. Found a post online of assembling the carpet back (http://sammo303.blogspot.com/2010/12...placement.html), and some post of general order of removal of things. However, i am running into problems and am greatly appreciating any help from the experienced! A ) Do i need to rip off the carpet from the white plastic? Can i glue it back together later? Two side glue tape?Location - below the door plastic frame protector (?name?) Revision: From the link i posted above i saw that the plastic stays intact/glued to the carpet. Now how do i remove the plastic from the doorframe? B ) How do i remove those plastic screws? I just managed to unscrew them some and loose the plastic and pulled the carpet from it. C ) The material below the carpet is really damp. After removal can i clean it or should i look for replacement? What is it? D ) The material under the carpet is damp and goes deep inside up there. How to remove? Is it washable? E ) How do i remove A and center console B? F ) Do i need to remove that center pillar and how? If you now of great DIY post or video online for this "operation" please share. Many thanks to all! Any advice is very welcome! Regards Igor Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 13, 2012 Share Posted June 13, 2012 Where the carpet is stapled to the white plastic strips, don't remove this as you will always have problems with the carpet moving and leaving a gap! Been there and done it lol Quote Link to comment Share on other sites More sharing options...
stef123 Posted June 13, 2012 Share Posted June 13, 2012 Tbh, you are probably best to just shampoo or steam clean the carpet. It's a lot of work to refit and you will probably end up with squeaks Quote Link to comment Share on other sites More sharing options...
artscot79 Posted June 14, 2012 Share Posted June 14, 2012 to do what you want to means gutting the interior seats trim etc a big job and a major headache as steff said ide steam clean it in place Quote Link to comment Share on other sites More sharing options...
Igorius Posted June 14, 2012 Author Share Posted June 14, 2012 TNX Stef123 ... So far here is where i am: Removal is stopped coz couple of problems: Should the top and bottom layers be one? Glued together? As you can see, they are separated in front and somewhere in the back they seem like being glued togerher - as one layer. Should i remove them as one? Can i wash the bottom layer? This upper part is damp also. It seems to me complicated to remove the inner corner towards the console. Should i pull or un-tight something in order to pull this out? The material to me has some similarities to cardboard (?!?) It seems to me to pull out the bottom layer i will need to unscrew at those two places? Should i cut here? To remove it as one i think all that cabling needs to be removed. And i if i don't cut, how do i deal with the vents? So far i cut it at the front... Thanks in advance! Regards Igor Quote Link to comment Share on other sites More sharing options...
