giorgi Posted August 3, 2012 Share Posted August 3, 2012 i have a 2009 ford fiesta edge, i turned the radio on the other day an i could barely hear it i usually have it on 8 an its quite loud but now on 30 i can barely hear it. i took it to my local mechanic an he basically said he dont know an to take it back to ford but my warranty has run out or to a radio specialist but i dont wanna get rip off because i dont know much about cars Quote Link to comment Share on other sites More sharing options...
NorthSussex Posted August 3, 2012 Share Posted August 3, 2012 Welcome to the Forum. Bit of a long shot, Try disconnecting the battery, and then reconnect it and re-enter the radio code, hopefully this will re-set the radio. Quote Link to comment Share on other sites More sharing options...
iNath Posted August 4, 2012 Share Posted August 4, 2012 FYI there's no radio code to enter on the current shape Fiesta. Quote Link to comment Share on other sites More sharing options...
ging Posted August 4, 2012 Share Posted August 4, 2012 pull the head unit out its usualy on the back if not look in your radio manual it may be in there some even come with a radio key card with it on good look if not it will need to be re-coded Quote Link to comment Share on other sites More sharing options...
jeebowhite Posted August 6, 2012 Share Posted August 6, 2012 check the simple things, make sure that your balance and faders are all on 0 or positive numbers, if they are all set to negative numbers, that would massively reduce the volume Quote Link to comment Share on other sites More sharing options...
