Introduced by fundamentally flawed beaurocrats , , , , :angry:
  • Replies 547
  • Views 206.4k
  • Hey up chaps. Bit of an observation on this topic. I've had mine done for some time and the engine management light was always lit. After reading some other threads on these forums (and other websit
  • In case anyone was interested and following my tale of woe, I thought I'd finish the story because as I've found out, there's nothing worse than following a problem like your own, only to find they di
  • Logic dictates. The point of the blanking plate is to stop the flow to the egr in leaving a hole your allowing the exhaust gas through. Some bright spark thought it would stop the eml, which in a lot
Has anyone actually fitted the egr blanking plate to their mk3 1.6 tdci focus and I stress mk3 simply because of all the photos posted there is a difference in how the engines look between the mk2/2.5 and mk3. Ok they're essentially the same engine but I'm sure ancillaries are different. I've ordered a blanking plate with a gasket and want to know if it is/was easy to do on the mk3.
Been doing some reading here and there and whilst researching teraclean I came across a company that has a product Archoil. AR6400D has rave reviews so I've ordered some of it (diesel additive to clean carbon etc build up) and their engine flush which again got rave reviews.
I use Archoil - one of the very best i.m.o.
Sold by power enhancer in the U.K. - very high quality professional products :)
lenny swears buy it keeps pluggin it on here must have shares in the company :D
Lenny uses Atomex too - another top notch product
I only recommend tried and tested products
independent non biast advice if somthing is good I'll recommend it.
I'm not currently selling anything of which I recommend nor profiting from any commission base sales
in fact; I even lost almost 4 euro today see link:
http://www.fordownersclub.com/forums/topic/74411-you-had-one-job-experience/
Hi, I have a 1.6 Focus and I buy a Egr blanking plate but then I repaired that it was 1.5 aluminium do you think that it can break or I have to buy one of stainless steel ? :(
Get stainless steel, aluminium will burst through
Sent from my GT-I9195 using Tapatalk
Aluminium is likely to melt - it must be stainless steel
never use aluminium blanking plate,
They melt and break through dumping metal in to your engine very bad indeed.
Stainless Steel is king 👍
Ok
The seller already sold 900+ plates for the 1.6 TDCI and he didn't had any problem till this point, and also the plates look good quality aluminum of 1.5mm
basically what im reading is; the seller has potentially harmed over 900 Citröen,Peugeot engines and has no problem with it because there making a profit from it.
There's many businesses operating like that both legal and illegal ☺
It takes a different C&C machine to cut stainless steel perhaps the seller doesn't have this type of C&C machine.
there are many suppliers of the Stainless Steel plates
I'm not pushing sales for Any particular only the material construction matters.
I'm not saying that the seller hasn't potentially harmed over 900+ engines, and I agree with you steel is king, but what I don't understand is why mostly 900 buyers didn't had any problem with it.
Is it because the alu used is fairly good quality or it only had melted in extreme cases or in cases of very minimum thickness ?
I think that in my opinion it can be a lot of cases involved, but like you say steel is king and if possible go for the best if you like your engine :)
Stainless Stee: ebay.com/itm/121026206109
Aluminium: ebay.com/itm/120938099227
Thing is psgskull, how would they know until it's too late? You buy a blanking plate today, it arrives tomorrow the right size etc, you say "great postage speed, good cost, product fits" short while down the line when something bad happens and what can you do?! Can't re review the guy....
That being said, I better take a magnet to that blank plate I have lying around somewhere..
Did you had aluminium on yours ?
I was waiting to recive it this week so guess it goes to the drawer when it comes then. :(
Remember that there are two places where the plate can be used - the very, very, very hot place is at the exhaust outlet & the other very, very hot place is at the EGRV exhaust inlet.
Neither is suitable for an aluminium blanking plate i.m.o.
Haven't checked yet, I'll let you know when I do, although it'd probably be ages as I have a thousand things to sort out...
The plate arrived today and I decided that I'm going to put it temporarily till I order the stainless steel one and keep an eye on it.
🙉 why do the job twice when it's a pain in the 😣
to do once.
I'm done commenting 🙈🙊
You're going to need x ray vision to keep an eye on it
I'm done too
some folk just dont listen to folks in the know
I'm done too
to do once.
I'm done commenting
I didn't put the aluminium one in because the steel is coming this week and don't want to do the job twice, and yeah I recognize that that your opinions are right, and your just telling me the best way for me. I realized that I was just doing it my way and not listening but I stopped and think d a little and understood that you folks are right .
So sorry for any inconvenience.
Thanks for it. ;)
