flibble22 Posted August 3, 2013 Share Posted August 3, 2013 Hi guys, Over the past few months my 2002 Focus has developed a creaking noise that's seemingly coming from the front-end. It happens mainly while setting off and turning at the same time (I do a U-turn immediately when driving away, at home) but I can still hear it to a much lesser degree when driving normally, sub 20mph. It sounds horrendous when turning. I did however, test a theory that something was dry. I set off about an hour after it rained and lo-and-behold, no creaking at all ! The only problem is I don't know what exactly it is, and I don't have the technical skill to solve this myself. The best description I can think of is that it sounds like walking over old wooden floorboards, but it's much more of a rapid sound. My brother is a mechanic however I have troubled him a lot recently with this car, and combined with his poor health, I don't want to bother him with something that clearly isn't dangerous, merely *very* annoying. So, I'd rather fix this myself, if possible. I know a good garage that won't attempt to rip me off though I'd like to know roughly what's wrong before going... Thanks for any help! :D Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 4, 2013 Share Posted August 4, 2013 2 possibilities thats the track rod arms are worn or the suspension is in need of a grease up get a can of spray white grease and spray all the moving suspension parts such as the wishbone bushes and track rod ends its extremely common particularly when theres a mix of wet and hot humid weather i think the rubbers just dry out a bit Quote Link to comment Share on other sites More sharing options...
stevebr Posted August 4, 2013 Share Posted August 4, 2013 Morning, I've got this with my Focus as well. Sounds to me like the rubbers are dry and need a greasing-I'll have a look at mine and report back. Steve Quote Link to comment Share on other sites More sharing options...
artscot79 Posted August 4, 2013 Share Posted August 4, 2013 i grease mine every 6 months anyway but the mk1 did it and it was non existent after regular greasing its cheap so if it works heho Quote Link to comment Share on other sites More sharing options...
flibble22 Posted August 6, 2013 Author Share Posted August 6, 2013 Thanks for the responses guys - is the greasing something I can do myself or am I best taking it in to a garage where I assume it wouldn't cost much at all? I don't have a jack and I assume I would need that, at least... Quote Link to comment Share on other sites More sharing options...
bt_cav Posted August 6, 2013 Share Posted August 6, 2013 I had the same problem, the ball joint gaiter had torn allowing the grease out and the rain in..... wearing out the ball joint I replaced the arm today (1 of the bushes was totally destroyed also) I found out the ball joint was making the noise by laying on the ground touching bottom of the ball joint and have someone gently bounce the car and I could feel the vibration while creeking was heard.. Quote Link to comment Share on other sites More sharing options...
