the swan Posted November 9, 2013 Share Posted November 9, 2013 hi, ive had quite a nasty bump on my nearside wing and needing to replace it, is there any sort of guide or anybody know how to remove the panel and replace it with a new one? Quote Link to comment Share on other sites More sharing options...
shabazmo Posted March 1, 2017 Share Posted March 1, 2017 Hi, did you find out how to remove the wing panel. Thanks Quote Link to comment Share on other sites More sharing options...
Ian Lanc Posted March 2, 2017 Share Posted March 2, 2017 21 hours ago, shabazmo said: Hi, did you find out how to remove the wing panel.Thanks You might not get a reply! that member was last on the forum in November 2013. Best just asking a body repair specialist, a quick call and they'll soon be able to tell you. Quote Link to comment Share on other sites More sharing options...
mikeyd1 Posted March 3, 2017 Share Posted March 3, 2017 It's only a few bolts mate Quote Link to comment Share on other sites More sharing options...
shabazmo Posted March 3, 2017 Share Posted March 3, 2017 Thanks Mickey, but the side door window seems to hide a couple of bolts. does the side window need to be removed. 1 Quote Link to comment Share on other sites More sharing options...
iantt Posted March 3, 2017 Share Posted March 3, 2017 only 1 bolt hidden, but you can access it with an open ended spanner, and give the bolt 1 turn anticlockwise, this will be enough to slide the wing out (the hole on wing is slotted 1 Quote Link to comment Share on other sites More sharing options...
shabazmo Posted March 3, 2017 Share Posted March 3, 2017 Thank you. Much appreciated. Quote Link to comment Share on other sites More sharing options...
