MERCIAN Posted July 29, 2009 Share Posted July 29, 2009 I own a focus tddi estate and recently I have been getting a humming/droning noise when I reach 50mph ( it is literally bang on 50mph). It subsides slightly past 50mph but does carry on. I recently had two new tyres on the front, one of which was not balanced ( but i dont think noise started immediately after fitting.) I have also had two front wishbones fitted at the same time. Garage has checked wheel bearings and they are okay. Any ideas? Quote Link to comment Share on other sites More sharing options...
sr-performance Posted July 29, 2009 Share Posted July 29, 2009 hi mate, make sure your tyre's are not out of shape, it does happen!! Quote Link to comment Share on other sites More sharing options...
MERCIAN Posted July 29, 2009 Author Share Posted July 29, 2009 hi mate, make sure your tyre's are not out of shape, it does happen!! Thanks for the reply. Noise is almost certainly coming from front of car. There is no vibration connected with the noise and no noise/vibration from gear box. <_< Quote Link to comment Share on other sites More sharing options...
sr-performance Posted July 29, 2009 Share Posted July 29, 2009 If you jack a wheel up and spin it you can usually see if its out of shape... Quote Link to comment Share on other sites More sharing options...
MERCIAN Posted July 29, 2009 Author Share Posted July 29, 2009 If you jack a wheel up and spin it you can usually see if its out of shape... ok will try it Quote Link to comment Share on other sites More sharing options...
bill07 Posted July 30, 2009 Share Posted July 30, 2009 first you should always get the wheels balanced,it could be causing all kinds of problems,think how much force could be created by 5 gram weight spinning on the end of a piece of string at that speed. second what tyres did you fit, if they were cheep and nasty they are proberbly the problem. Quote Link to comment Share on other sites More sharing options...
MERCIAN Posted July 30, 2009 Author Share Posted July 30, 2009 first you should always get the wheels balanced,it could be causing all kinds of problems,think how much force could be created by 5 gram weight spinning on the end of a piece of string at that speed.second what tyres did you fit, if they were cheep and nasty they are proberbly the problem. One was a budget tyre and one a Firestone. Firestone( never used ) was my spare so tyre place just fitted it without balancing it. I am embarrassed to say that I havent checked the Firestone pressure yet Quote Link to comment Share on other sites More sharing options...
bill07 Posted July 30, 2009 Share Posted July 30, 2009 budget tyre can make alot of road noise,but so can low tyre pressure so check all the tyres. Quote Link to comment Share on other sites More sharing options...
MERCIAN Posted July 31, 2009 Author Share Posted July 31, 2009 budget tyre can make alot of road noise,but so can low tyre pressure so check all the tyres. [/quote Have checked all four tyres, rear passenger side was only 20psi. Have sorted it but still getting noise at 50. Will get tyres rebalanced at weekend. Cheers Quote Link to comment Share on other sites More sharing options...
MERCIAN Posted August 6, 2009 Author Share Posted August 6, 2009 Both front tyres didnt need balancing! So can just assume that budget tyre is culprit. Noise is much more noticeable on some road surfaces than others so must be " crappy " budget tyre. Get what you pay for I suppose! Quote Link to comment Share on other sites More sharing options...
