Disconnecting Battery
if i was to disconnect the battery for 10-15 minutes ,what would i have to reset or do like the radio code ,anything else thanks
just need your radio code or it will be lost and cost you to get
it
Windows will need resetting.
oh yes
reset the windows ,how is this done ?
It's an easy procedure basically involving running the windows up and down a few times etc, check your handbook in the section about removing the battery/jump starting and it'll be listed as window re-initialising. It's either there or in the section on how to operate the windows.
Basically the car loses it's anti-trap settings when you pull the power connection so the one-shot doesn't work until the procedure is run
